Question about SanDisk Sansa Clip MP3 Player
WONT TURN ON AT ALL
I plugged it into my computer to charge it
when i unplugged it, the refreshing database screen came up and there was a slash line through the battery icon, then it completely shut off
since then, it wont turn on at all
not even when plugged in
  • ericmontano Nov 07, 2008
    I decided to charge my clip via usb. While charging, pc power turn off (not power failure). I then check my clip. There's no light on even when there's still power before I charge. Is it already busted?
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
Try another USB port.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
The screen is stuck on a screensaver and it will not turn off or do anything
It often happens when it doesn't a file is corrupted. If it gets stuck on "Refreshing database", turn it off by holding the power switch until it shuts down, then plug it on a computer and when the sansa logo appears, unplug it. It will skip the datebase refresh and you'll be able to reformat it.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
On the intro screen it freezez and eventually goes to the next screen and says refreshing database but it dosent refresh
This seems to happen when the database gets corrupted.
1. Turn off the player.
2. Plug the usb cable to the computer, don't plug it to the player.
3. Slide the lock switch to the right, you will see an orange strip.
4. Hold the menu button to start the player. Don't release it yet. Wait until a shutdown message appears and the player goes off again.
5. Plug the usb cable to the player end. The player should go on again. The player should mount as a disk on your computer. Find this disk and back up its contents.
6. Format the player, as explained elsewhere.
7. Disconnect the usb cable. This time the database should refresh properly. Once this is done, slide the the lock switch to the left and turn off the player.
8. Turn the player back on. It should work, but you will have to load your stuff again.
9. Redo steps 1 to 5, except that now should copy your music, videos, etc, back into the player.
10. Repeat step 7.
11. Turn the player back on. It should work again.
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Stuck on database refresh
1. Try going into recovery mode (turn off the player, put the hold button towards the earphone jack, turn on and hold record button)
2. Plug in the sansa into the computer
3. Open the device (should be called 16MB)
4. Create a folder in the device called "sansa.fmt"
5. Eject and unplug the device
6. Should reformat and it will start back up
Jul 20, 2009 | SanDisk Sansa e260 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Sandisk sansa e260 refresh database error
is there a reset butten somewhere on it well if it is then get a paper clip and un bend it a press rest and then turn on your sandisk sansae260 and see what it say and maybe that will sovle your problem Have a great happy fun day
Jul 20, 2008 | SanDisk Sansa e260 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
My screen freezes with "refresh database"
Dude, c'mon - you have a Linux based system - did you really think it was going to work? Just playing with you. I would check the Linux forums on this one - if you're smart enough to use Linux, then you're smart enough to grab software info from Sandisk's website/cust svc line and pass it to your Linux buddies to hack.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
99 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
