On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
    Problem Solver:
  • 12 Answers
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Posted on Oct 21, 2008
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
The paper does not feed correctly so that the paper goes into the machine crooked causing a paper jam.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 27, 2011 | Canon Office Equipment & Supplies
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
When we are printing, the paper does not feed in straight, we have a Canon MP 460.
90% have saved an object in the printer,must undo to remove the foreign body.
Mar 13, 2011 | Canon imageCLASS MF7480 Laser Printer
The paper consistently jams in my Canon MP460
-check the paper feed guide rollers, clean with a cotton swab
Sep 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
I have canon PIXMA MP
E3 error on the MP150 is a paper jam error. Make sure that there is nothing obstructing the paper going into the printer and that the feed mechanism doesn't have anyhting in it. Also run a roller cleaning from the printer software.
Nov 23, 2008 | Canon Office Equipment & Supplies
1,426 people viewed this question
jasbo
jasbo
