Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Replace key assembly
Older model 42 inch deck 18 horse power 6 speed i lost keys and now it is striped wondering iwhere to buy mabey used key assembly or even new
  • 48 Answers
Any small engine repair shop should carry that switch - or sears . com - just put in your model number
Posted on Oct 22, 2008
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How to replace drive shaft key
Remove battery and holder. Remove clip from top of pulley
remove pulley, replace key.
Jul 24, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My Poulan 42-Inch 17.5 hp Briggs and Stratton Engine with 6 speed will not move. The motor runs fine but when I go to put it into gear the mower will not move whether it be in reverse or any of the forward...
Assuming you have checked the main drive belt and it is snug, I think you have a problem with the hydrostatic drive. These are replaced with used or new, ain't cheap either way.
Jul 15, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Can i replace a 17.5 hp mower engine with a 18 hp engine?
You will need to shop carefully. That is not too much of a power jump to worry about ruining axles, gears and the like. BUT, do be mindful that you have to shop an engine to match two very important criteria:
Bolt patterns and spacing: This is how the engine will attach to the mower's deck/chasis.
Output shaft length, diameter, taper and if it's keyed or non-keyed.
If looking to just replace a tired old iron horse, similar make and model to the original with slight power upgrade cannot be helped - but the bolts and shafts will be pretty much spot on.
May 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
