Question about Yamaha Portable Keyboard
Yamaha w7 I can't get the drums to stop playing when trying to play the key board.
I'm looking for parts for the Yamaha W7 keyboard.
Posted on Feb 20, 2009
My Yamaha psr e303 all keys from bass side stop playing what can I do?
You might have the accomp switch turned on?
If not try holding down the highest key whilst turning the keyboard on, this will start a factory reset.
Sep 18, 2016 | Yamaha Music
C-notes are not playing and not getting a signal
the main line on the c note that goes to the main board seems not ok, u will need a qualified technician to check and advise. this may be caused by liguid pouring on it, moisture leading to rust corroding the terminals.
Feb 20, 2015 | Yamaha Music
YAMAHA PSR 9000 D NOTE VERY LOUD INTERMITANT
If you have any key note problems with your yamaha psr 9000 and need It repaired contact a qualified engineer at stephenhns5@gmail.com
Jan 28, 2013 | Yamaha Music
MY YAMAHA PSRS-550B, TWO KEYS PLAYING WRONG TUNES
guys i am using psr s 550b for 2years,,.and the problem was i stopped useing it for 2 months ....and when i started using it again my keys r not working only the styles r playing ....and i thought to do format since the keys r not working i am enable to format it ple tell me any solutions for it .ple.pleeeeeeeee
Dec 05, 2012 | Yamaha PSR-S500 Digital Keyboard
Yamaha YPT-410 When playing the keyboard, the sound cuts out when playing multiple keys, and then begins again only to cut out again. Does not matter which keys. I have done a factory reset and it did not...
It's probably your keyboard. Some keyboards are limited with it's polyponic capabilities. Some can play many notes at one time, some cut out when it reaches it's limits. Check your manual for specifications.
Aug 25, 2011 | Yamaha Corporation Of America 61 Key...
My Yamaha PRS-293 will not play any of the E keys or the Bflat keys. I reset it once (power up while holding the highest note key) which fixed it once. Now it won't fix it. The MIDI plays all of the notes.
The key switches are scanned as a matrix. One of the matrix wires has broken or connector/cable is not making it... It will be a connection in common with the non-working keys.
Here is schematic:
http://elektrotanya.com/yamaha_psr-293_sm.pdf/download.html
On page 40 on the board labelled 61H-MK and the connector DMLCD-CN401 the connections to pins 11 and 12 with signal names N14 and N24 have become broken or disconnected before they get to the processor board.
Since these lines are NEAR an edge, the cable could be not quite in the connector at one end or the other. These two wires are what triggers the E and the A# key signals. There are TWO contacts per key as one closes first then the other... this is how they measure key velocity.
Jan 17, 2011 | Yamaha Music
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
Middle c will not play -- how do I get to the contact?
If this is a Yamaha synth (you didn't say what type) often the keys are done with conductive rubber "pills" that are pressed onto fingers of circuit traces on a board under the keys.
To clean, you have to dis0assemble the unit to get at the contacts. Often th keys will have the conductive pills in silicon rubber domes taht ALSO act as the key spring.
When you dis-assemble the keys whcih are usually in groups that have many screws retaining them, you can clean the pills in the silicon domes AND the traces on the circuit board with 99% isoprophyl alcohol.
A fatal problem sometimes happens if keys have been smashed down and there is a crack in the key circuit board. The board must be replaced and can be procurred from Yamaha Parts at Yamaha America in California. The Key circuit board is usually in a couple parts. The circuit traces where the pills hit have a very hard carbonized coating.
Dec 16, 2009 | Yamaha Music
I HAVE PSR S900 KEY BOARD THE KEY BOARD SYSTEM FILES ARE ERAISED IT PLAY BUT SOUND IS NOT COMING
Do a factory reset. Refer to page 79 of your owners manual.
Manual download if you don't have one:
cachepe.zzounds.com/.../psrs900_en_om_b1-582b8f6c0740eeb85233b92e67b9e28a.pdf
Aug 12, 2009 | Yamaha Music
Yamaha Portable Keyboard Logo
296 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
