Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool QP II dishwasher - Not draining
My dishwasher has stopped draining, I would need to drain it 2- 3 times before it emptied, now it will not drain at all. It sound like it is working but nothing comes out through the drianage hose.
  • heathersteve Nov 12, 2008
    I have a dul100PHQ0 it wont drain but the motor is working. The motor pumps water into the machine. The machine runs and spays water,it just wont drain.
  • Anonymous Mar 03, 2009
    my dishwasher will not drain
    Problem Solver:
  • 3 Answers
I had the same problem... I jiggled the washing machine.. the discharge hose seemed to be clogged.
Posted on Nov 21, 2008
Fills up with water and then empties straight out
Thanks for writing to Fixya.com.
Is your drain hose stopped up with debris - have a double sink next to the dishwasher. You can plug both drains, one at a time with the water running in the sink while holding the other drain closed. Try it first and if it works, its free, otherwise you may find it's another issue like maybe a bad pump motor on the dishwasher.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 27, 2010 | Whirlpool 24 in. ADG7540 Built-in...
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Waher fills up and empties at the same time
you definalty have a drain hose issue, id bet that either your drain hose is lower the nte hunit itself or even connected to and outside drain sorce with out any "air gap/brake" i the drain line.. your creating a siphon action, you drain line should drain into a stand pipe no lower the n the back of the units console
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag mdb8600awq dishwasher drains good 20 seconds and stops
Dont know if you still have this problem, what I did was this - press the start button and keep going until you reach the number '2'. Leave it at '2' and in a couple of seconds it will start draining the rest of the water. Worked for me.
Feb 19, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
139 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
