Question about Philips 27PT6441 27" TV
Menu,sound problems my tv will not stay off once I press the off botton I'm also having a problem with the volume sometimes it goes all the way up and stays sometimes it goes all the way down and stays or do both changing back in fourth Then the menu pops up goes thru everything changing my settings All while I'm watching something these problems happen every 20 sec or so.
    President:
  • 3,130 Answers
First thing is try to take out the batteries out of the remote control Then if the problem persist, unplug the set for a couple of hours if not over night. If that dosent work then check to see if any of the front panel buttons may be stuk .. If all of this was checked its time to call in a repairman as you have a microprocessor circuit or EEPROM fault or the five volts going to the reset is too low. Good Luck
Posted on Jul 26, 2006
How do you switch to video mode with no remote
hi,
you cant.
your going to have to get a mid priced universal with extended features. read the packaging. thrift stores sometimes have a bag wall with old remotes so if you have someone who goes to the thrift store sometimes tell them to start looking for either a vcr or tv remote that says emerson on it for you. directv and dish network universals have video input buttons, if you have eith of those providers go to their website, download or find the chapter where it shows how to set up your viseo input. it is shut off by default..
jm
Apr 14, 2011 | Emerson EWF2004 20" TV
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Have a Mitsubishi TV wd60735 the tv volume just increases to max by itself, sometimes won't turn on, sometimes no remotes will work it and I have to pull the plug to reset it to get it to come on, have it...
Sounds like your tact switches on the front of the TV are shorting out. Unplug the plug for the switches. if the problem goes away then try to clean the switches with rubbing alcohol, if still has problem replace switches.
Aug 27, 2010 | Mitsubishi WD-60735 Projection Television
Need code to enter for universal remote
-as usual; try to start tv with the power botton on set.
-press and hold tv botton on remote untill the led light stays on
-the with the rate of one second press on/off botton on remote, aim the remote at the set
-when the tv set goes off immediately press enter on remote.
-this will program your remote, but still you dont have the code for the future when changing batteries.
Aug 26, 2010 | Sylvania 6413TC 13" TV
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
My monitor menu settings box keeps coming on right in the middle of the screen. Sometimes it will go off when I push the ''exit'' botton. But it goes on and off all the time. It makes it hard to do...
Sounds as if the "menu" button is making intermittent contact. Try spraying it with an electronic solvent (available from most Electrical/Electronic outlets. e.g. RS Components) and press it many times (Power off!). This may rid the button of any gunk in there.
Aug 07, 2009 | Computers & Internet
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Samsung 37
It sounds like your TV is set at Shop Mode. To veify that turn on your TV and press the info button on your remote, some info will be displayed, If Shop Mode appear please follow the next steps...
In order to change that mode turn on your tv, press the volume key (either one) on your front or side panel (Depends of the model you have) the volume bar will appear, once this happend press the menu key on the front or side panel and hold it for like 7 seconds, "Dynamic" symbol will appear at your screen this means that you are not longer at Shop mode. You can double check by pressing info button at your remote
Regards
Jan 14, 2008 | Samsung LN-T4665F 46 in. LCD Television
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
Philips 27PT6441 27" TV Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
