Question about Microwave Ovens
Microwave Stops after 4 seconds
Can pretty much hear a clciking sound on each second rotation.
Aaman does not seem to be responding although chat session is open.
  • Microwave Ovens Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
The clicking is common with inverter-related failure.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Oct 22, 2008
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 03, 2012 | GE Microwave Ovens
Set clock but time goes off
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Alarm list says motor rotation and cuts off
Sep 27, 2012 | Microwave Ovens
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
