Question about Jl Audio 250/1 Car Audio Amplifier
Please help Ok I had my amp hooked up and workin for some time now and just the other day the fuse in the wire blew. So when I replaced it and now the power on light comes on for a few seconds and shuts back off. I thought I had a bad connection somewhere in the ground or hot wires but i checked that and its not the problem.
    Scholar:
  • 72 Answers
Check to make sure you speaker has not shorted. Try a different speaker. If this is not the case you could have an internal shorted transistor inside of the amplifier. or in some cases both. If it is in the amp and you are comfortable working on the amp remove the cover and along the side connected to the heatsink. You will find the smps and the output transistors. use an ohmeter and check across the three legs one way you sould get one reading and if you flip the leads you will get another. if you encounter no resistance, no matter which way the leads are placed. That transistor will probaly need to be replaced. But check the speaker before you do anything. and the wires going to the speakers.
Posted on Aug 03, 2006
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
2002 chevy prizm 4cyl auto has a problem blowing fuses and no running light or headlights
maybe one of the light connections is grounding out? check the light holders to make sure there is nothing pinched or worn through on the back of the lights.
Jun 19, 2012 | Chevrolet Prizm Cars & Trucks
I hooked up a car amp and when i put the fuse in,it blew.then i disconnected the power,installed the fuse and as soon as i touched the power cable,the fuse blew again...
Hello
Some kind of dead short is there. It may be inside the amp circuit of with outside wiring. You have to find it by meter check. Contact a auto electrician and let hinm detect the fault. OK.
Jan 16, 2012 | Pioneer GM-X354 Car Audio Amplifier
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
1996 VW Jetta electrical problem
the battery was charged backwards,or the battery is hooked up backwards.
Oct 28, 2009 | Cars & Trucks
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
95 Geo Tracker Dash Lights out?
replace the blow fuse
above left knee, fuse panel there.
1 is blown.
your amp was shorted, it blew and took out what oem wiring they hacked into .
bad installation.
Sep 09, 2008 | 1995 Geo Tracker
Transformers and fuses keep blowing
If you are where it's warm and you are using air conditioning, have the technician check the coil in the relay in the outdoor unit. I replaced 2 transformers before I figured out the coil was shorted out and drawing too much current.
Jan 04, 2008 | Goodman GMS90703BXA Heater
Hok up amp and all fuses blow on distribution block
somehow, DC car voltage has gotten to the speaker outputs of your amp! your fuses are saving your speakers from meltdown. your amp has melted down. toss it after checking with ohmeter as follows: disconnect amp completely. red wire from ohmmeter to +12Vin. black wire to SPK+. if ohms are anything below 1000 ohms, then toss it. An electrical short is equivalent to flooding your entire house with a leaky faucet. No telling what that rapid current will encounter along the amplifier section. you could get lucky and find all power MOSFETS have shorted and replace them. good luck.
May 31, 2007 | Jl Audio 500/1 Car Audio Amplifier
AMP not workin
if you saw smoke something fried, im surprised it still kicks on at all. my best advice is if you kno how to use a soldering iron, see if you can locate the problem, (i.e. melted wires and such), if not best would be to look for a new amp. hope this helps
Sep 19, 2006 | Lightning Audio LA1.150.2 Car Audio...
Jl Audio 250/1 Car Audio Amplifier Logo
125 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
