Question about Sharp R-308H Microwave Oven
Sharp R-305KS door release problem
From moment of receipt, the door release push button did not have any resistance to release the door. Could the lever have been broken in shipment? Is this a replacement part? Where do you obtain the special hex type screwdriver head to remove the sheet metal housing?
  • Sharp Master
  • 8,934 Answers
Yes it is possible the door open lever got broken in shipping.
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Once the cover's off, you can see the door opening parts. It's probably the lever.
The best place to order Sharp parts is Tritronics.
Posted on Oct 22, 2008
Why will door not open
This happens when the latch hook loosens up and moves so that the door will not open when you press the button.
It's a very easy fix, but should be done by a repair person so that the door can be adjusted propery and no microwaves escape.
Hank
Jul 22, 2014 | Sharp Microwave Ovens
How can I replace/fix the button spring?
remove the outer case and look for the button spring inside / OR take it to a repair shop .
May 09, 2014 | In Cuisine MM800FS Microwave Oven
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Jan 14, 2011 | Sharp R-1511 Microwave Oven
The door release button/handle doesn't travel far enough to release the door without pulling on the door
REPLACE THE PUSH BUTTON.SOMETIMES IT GETS WORN OR THE PLASTIC "***" HAS BROKEN OFF;COMMON PROBLEM.HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Sharp Microwave Ovens
Buttons don't work
Hello there:
This is normally caused by a faulty touch pad that is failing These touch pads are replaceable but they can cost about 60 to 100 dollars depending on the exact make and model ok
I hope this is very helpful for you
Best regards Michael
Dec 11, 2009 | Microwave Ovens
Door won't open. push button doesn't work
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 06, 2009 | GE Microwave Ovens
Unable to open the microwave door since this morning. the oven still works but its closed. when press at the bottom right side corner, the door supposed to be open.
More than likely, the little lever behind the button has broken. You may notice there is less resistance when pushing the button, but perhaps not if your model has a spring behind the button as well. If your handy, you could remove the front panel and take a look at it, but if you dont feel comfortable doing this, it may be equally as expensive to repair this as it would be to buy a brand new one. I'm assuming its out of warranty at this point, but if not, send it back!
Sep 11, 2009 | GE Microwave Ovens
Sharp R-308H Microwave Oven Logo
144 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
