Question about Sanyo 09KS51 Mini Split Air Conditioner
York Mini-Split Not Cooling? : (
My York 12000 BTU mini-split is not cooling and don't know why...
The indoor wall unit works fine. The fan is rolling. We can feel the air is moving in normal condition but the air is not cold.
The outdoor unit seems to be working, too. I checked the piping (20 feet bewteen each units):
The thinner copper pipe is very cold near the outdoor unit. However, it's less cold in the middle part. Worst, the part near the indoor unit is slightly cooler than room temperature.
The outdoor unit's fan is working. Not sure about the compressor / condenser part.
Any idea?
Thank you in advance.
Emeo
  • martos reynold Sep 21, 2012
    did you checked the refrigerant try to checked the refrigerant and also the current of compressor
  • Anonymous Mar 27, 2014
    Where can we buy an indoor fan motor for a 60,000 btu Hide away unit Model No GD60HMFS/u Fanmotor Model YSK139-300-4ad
Try to check the amp of supply and check the current required if not same posible problem is leak of refrigerant
Posted on Dec 29, 2011
  • 76 Answers
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
LMN096HVT
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | LG LMN096HVT WaMounted Mini Split Indoor...
Not cooling good and has an odd smell.... We've repaired a leak in freon in 2 places in the last 2 months!! ugh!!! I'm so frustrated with this thing.... it was cooling like a dream when we first installed...
Where were the leaks in the system. If they were in either the indoor or outdoor coils, I would replace the entire system. If they were in the refrigerant lines that connect the indoor and outdoor units, I would replace the line set only.
Oct 29, 2013 | AMVENT 12000 BTU 1 Ton Ductless Wall Mount...
I am looking to buy a mini split ac/heating 1 ton unit. I want to know how high from the floor does the unit have to be to cool and heat a 10 x 20 room?
Hi, when you buy your split system, the indoor unit will mount on your wall off off the floor a distance that the factory has made it for. With an 8' to 10' ceiling, it would be about 7' off the floor. This all depends on the refrigeration plumbing coming from the outdoor condenser to the indoor unit. It will tell you all of this on the installation kit for this unit, as the plumbing for the freon pipes are already pre-made for a certain height. A 1 ton, (12,000 btu) unit will have no trouble cooling a room of this size, so check with the manufacture on the height it will be.
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Goodman Heating & Cooling
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
Sanyo 09KS51 Mini Split Air Conditioner Logo
1,612 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
