Question about Palm IIIxe
Software prevents computer Stand By
The dock for my Palm IIIxe is plugged into the COM1 port. Whenever the system tries to go into a standby mode, this message pops up: "The device driver for the 'Communications Port (COM1)'device is preventing the machine from entering standby. Please close all applications and try again. If the problem persists, you may need to update this driver." I've tried removing the dock and the software (using the "Remove programs" tool), reinstalling the software usingine the most recent available, and every possible combination of these things, with complete system shutdowns in between each. It doesn't help. Is there something left hanging in a registry or somewhere that needs deletion? I realize that I may lose the use of the dock, but that's preferable to all the shut down/turn ons that I'm doing. I'm running XP on a custom system.
3 Suggested Answers
  • 473 Answers
SOURCE: HotSync fails using PalmConnect/Palm V on XP-Pro Tablet PC
This one is simple - Tablet edition is not supported. Sorry to break the news to you but palmOne soes not support synchronization with Tablet editions of Windows. If you can get it to work, great but you cannot get direct support for it.
Posted on Sep 11, 2005
SOURCE: Outlook on IBM T42
I dont know how to work my palm pilot m505
Posted on Dec 18, 2009
How do I open COM1 in Windows 7 Pro?
Com1 is the Communication Port. A serial Port located on the computer and usually 9 pins.
Feb 18, 2014 | Computers & Internet
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
HP Elitebook 8540p is getting no video in docking station
Try this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=au&prodTypeId=321957&prodSeriesId=4097214&swItem=ob-83668-1&prodNameId=4096169&swEnvOID=1093&swLang=13&taskId=135&mode=4&idx=4
Jun 23, 2010 | HP EliteBook 6930p Notebook PC
Tried to start up Palm IIIxe after a couple years and it seems to not work at all. Is there a trick or something special that needs to be done to it? I tried the reset button, but that didn't work either.
A very basic question would be if you've fully charged the battery pack. It is very likely to have gone dead in the interim, which means you'll have to reload everything (other than the ROM-based software that came with it) once the unit returns to life.
Apr 13, 2010 | Palm IIIxe Handheld
Palm set to COM1 not serial connection-won't sync
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Normal 0
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Nov 10, 2009 | Palm Z22 Handheld
I have a Dell Inspiron 530 using Vista Home Premium and have just tried to reintroduce a Palm M130 which I used on my last computer with Windows XP. It worked ok then. Now I cannot find the COM1 port. In...
is the printer connected to the pc or have u ever tried installing the printer on the pc as by default the printer is kept on com1 port
just check & let me know if the issue is resolved.
Apr 17, 2009 | Compaq Evo D310v PC Desktop
My Dell PowerEdge 2500 has 2 configurable com ports which are setup as Com1 IRQ-4, and Com2 IRQ-3. My problem is that everything seems to say that they are there and active, but my software only can talk...
That "in-op" COM port is in fact, probably defective. Had many cases where 1 works/1 doesn't. Buy a cheap, PCI COM port board, install the software, and plug away!
Cheers,
gurutim
Mar 19, 2009 | Dell PowerEdge 2500 Server
Palm iiixe installation
The problem has been resolved, thank you.
Dec 15, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Outlook will not sync with Tungsten C
Check you sync part of your desktop program and make sure you have outlook checked for transfer. Right click on Synch on bottom tray and select custom set uo
Sep 11, 2005 | Palm Tungsten C Handheld
Palm IIIxe Logo
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
