Question about Brother MFC-5460CN All-In-One InkJet Printer
Lost disk for my brother mfc 665 cw printer so what do i do
I have lost my disk and i dont know what to do? i have tried everything that i can think of. so anything would help.
    Problem Solver:
  • 12 Answers
You can always Download the latest drivers, software updates and utilities from their website. here is the link:   http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc665cw_us_as.html?reg=us&c=us&lang=en&prod=mfc665cw_us_as
Posted on Oct 21, 2008
  • 6,487 Answers
How do I set my Brother NFC 665-CW to print multiple pages?
do u mean the whole multi-page doc or multiple copies of the same page?
the former would be what u tell it to print (whole document vs current page). The latter would be in the printer properties config page.
Sep 21, 2014 | Brother MFC-665CW All-In-One InkJet...
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
My Brother MFC 495 cw scanner won't work
Hello i just bought a Brother MFC-495CW printer and for the life of me cannot get wireless to connect even though i have setup everything correctly as far as i know. Any help would be appreciated.
Dec 16, 2009 | Office Equipment & Supplies
My Brother Printer MFC 665-CW just came up with a message Unable to Print 4F
Hi there
Worth a go/
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Mfc 665-cw magenta clogged?
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
Mar 28, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
INSTALLATION
this is a complex machine, without its documentation it would be very hard to figure out, so the install and setup guide is available from brother, its available here
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_665CW_EN_382.PDF
and here is the units operator manual, this will take you to it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
following the install guide is pretty straight forward and should result in a satisfactory setup.
Oct 17, 2007 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
