Question about Brother IntelliFAX 560 Plain Paper Fax
Faxing I cannot fax anything outside of my area code whether I use 1 or not.
  • inx01 Sep 06, 2008
    Every number I try to fax to I get a busy singnal. There is no need to press a number for an out side line.
  • 417 Answers
You could try pressing the on hook dial button once you have a dial tone dial the fax number you are trying to reach and then you will be able to hear f there is a fax tone form the other machine or a error message from your operator. If there is a series of beeps with the document in the feeder press send.
The most common cause of not sending is ECM (Error Correction Mode) press menu and within TTI settings make sure this is turned off.
Hope this helps you
Thanks J
Posted on Jan 06, 2008
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
When we dial a 1 800 fax number, our fax machine dials, but the fax doesn't go through. Instead, we get this message: "We're sorry. You have dialed a number that can not be reached from your...
Pretty simple....some people when thy set up a number with the phone company only want it to be accessible from a certain area...for instance a number ( 1-800 ) could be set up to only allow calls from within the USA and not allow calls from outside the USA.
Nov 17, 2010 | Office Equipment & Supplies
How does I fax something from my Canon MX320?
Follow these steps :
Prepare the document that you want to fax.
Prepare a fax cover sheet, if desired.
Open your fax software - such as Microsoft Fax or Microsoft Exchange.
Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item.
5
Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed.
6
Indicate whether you wish to send a cover sheet.
7
When asked to attach the file, follow instructions to attach the file that you want to fax.
8
When ready, click Send. The fax will begin to compile the information and, when ready,
9
When the connection is made, the fax will be sent.
Oct 26, 2010 | Canon Office Equipment & Supplies
My Samsung F555P can receive faxes, but I cannot send them. It doesn't finish dialing.
check for "fax set-up " problems. such as area code, disable call waiting, outside access code enabled.
Nov 16, 2009 | HP 1220 Plain Paper Inkjet Fax
I have a lexmark fax/copier X4270 I can receive faxes but can not send them please help
If you can receive a fax but can't send them, then the G3 fax board is working. It is therefore a settings problem in the unit or a telephone company issue. Review your TX settings and confirm that you have not turned off the send option. If that's ok, then move the fax unit to a different telephone wall outlet and try it. Are you sure your telephone agreement allows out of area dialing? If you have only local service, you'll not be able to dial out to anything outside your local area.
Aug 28, 2009 | Office Equipment & Supplies
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark 5495 Fax Problem
Go to Start->All Programs->Lexmark 5400 Series and launch the Lexmark Fax Solutions.
Click on the Tools menu and select the Adjust Fax Settings option.
See if there is anything in the Dial prefix.
Steve
Nov 03, 2008 | Lexmark X5470 All-In-One InkJet Printer
FAX TRANSMISSION
I have had this issue as well faxing to any area code in general outside of my own. The only thing I found to work was manual faxing. This comes from the manual.
Dial manually from the handset
1. Load the document into the ADF.
2. Call the recipient on the handset.
3. When the recipient is ready(when you hear the fax sound), press Start Fax on the product control panel.
Oct 03, 2008 | HP Laserjet M1319F Laser Multifunction...
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Brother IntelliFAX 560 Plain Paper Fax Logo
122 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
