Question about Mitsubishi VS-50705 50" Rear Projection Television
VS-50705 Picture shrinks to the top of the screen. Now I have it in a room that is 60 degrees, no problems!
I am asing this question even though I have read as few answers. I am asking because of the area the TV in in now.
The screen was shrinking to the top. The next day I would turn it on and sometimes it would be ok for a while or shrink right away. The last year I have left the Tv in a room that is roughly 60 degrees. I turned it back on, plugged a DVR into input 1 and it has been working fine ever since. I have left it on for 48 hours and it still works.
I am assuming if I put it in a warmer location it will not work again. I would like to save it for the garage if possible.
With the details I provided what Cap could be the problem if it is a Cap causing the problem?
Any thoughts would be great. Thanks! AL
  • 905 Answers
This is not a cap but a conversion problem, the conversion IC chips control the horizontal , vertical ,and color alignment , but there is also some resistors on the conversion IC's that have been causing the set to look like they need the conversion IC's, so you could check there values and maybe only have to replace a resistor
here is an example of the STK conversion IC click here
Posted on Oct 21, 2008
    Genius:
  • 1,605 Answers
Now a days, TV don't have replaceable parts any more. the next best thing is to replace the board. it could be the HV, horizontal or the valiance.
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi 50705
Good Day, tree64;
More than likely the convergence problem the TV has wont be resolved by adjustments. In your situation, moving TV, the problem most likely is poor solder connections on the convergence IC's. They are large devices attached to very large heat-sinks, and have numbers on the IC'c like STK 392-560.
If no poor connections....replce.
Good Luck, big IRISH.
Jul 04, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs-50705
Maybe you have a problem with the Vertical out, and you need change it.
May 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Help me
Go tu SET UP menu and change de option of SCREEN SAVER to off position and try again
Mar 18, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
