Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Fills with water and that's it
Ours is almost 4 years old. Last night it filled with water and won't finish the cycle. It is sitting filled with water and won't do anything else. We know there's power because the dryer is still functioning perfectly. Any ideas?
  • Anonymous Nov 10, 2008
    I have the same problem. It fills with water and will still spin but doesn't drain the water. Now when I try to start it again it just makes a large humming noise and spins
  • 62 Answers
Ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Posted on Oct 22, 2008
My LG washer/dyer fills up with water after its done running, it washes and drys then fills up
something is holding the input valve open small pieces of rust etc. will do this .that is why they put screens in the ends of the hoses
Sep 23, 2017 | Washing Machines
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Year old frigidare washer won't agitate
the selector switch might be out.
Aug 08, 2007 | Frigidaire FWTR445R
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
