Question about Sony Cyber-Shot DSC-P32 Digital Camera
"Format Error" When I turn on my camera at the top right it flashed reading "C:13:01" and in the middle says format error. I've turned my camera on and off and even went into the set up, memory stick tool, then tried to format the memory stick. Notyhing has worked I need help. Thanks
  • babykish_06 Feb 05, 2009
    i have the same problem with my memory stick. it always say "format error" whenever i open the camera. please help
  • 40 Answers
Take an ereaser and clean the contact points on the memory stick. Then reformatt.
Posted on May 07, 2009
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    When the Camera is turned on it reads DCF Full Error. How can I fix this error?
    .try to format both...
    remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
    open your unit without sd card,,go to menu - setting - format -reset
    after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
    Feb 25, 2011 | Cameras
    When I turn my Camcorder on it says "Format Error please format"and E:31:00 flashes on the right hand side of the screen.
    The memory card may be corrupted. you have to format the card. you can do formatting using the camera and the option is in the setup menu. Otherwise connect the camera to computer and format as fat32. If unable to complete the format your card is damaged and have to buy a new one.
    Jan 06, 2011 | Cameras
    Error msg CHR flashing how to get it to turn off, inserted new memory card, even in off position continues to flash. D90
    Format the memory card. Press and hold the two [FORMAT] buttons until "For" blinks on the top display. Release the two buttons and then press the same two buttons again.
    Sep 26, 2010 | Nikon D90 Digital Camera with 18-105mm...
    Format error
    Format error means memory card in camera is unstable and need to be formatted. You will lose all data/ files on memory card after format.
    Format option is available in camera Menu.
    This will solve your format error problem in camera.
    Dec 18, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
    Card Error
    Are you getting this error with the card?
    If so, insert the card into the computer. Make sure you get all the files off before you continue. Then go to my computer, right click on the drive, click properties, click the tools tab and click check now. Just do Automatically fix file system errors and click start. This should successfully find errors if present on the card and fix it. You may lose a picture or two if you don't transfer all of them first. Or you could format the card by right clicking on the card drive and clicking format.
    If you get the error on the camera without the card in it, turn it on and click mode button twice to get to the picture display (it should be a black screen with "memory error" on top). Then press menu and use the 4-way button to go to the right for Setup. Then use the 4-way button to go down to format to format the camera.
    This should fix it.
    May 05, 2009 | Sanyo VPC-S880 Digital Camera
    Blue screen access error when viewing or taking pics or vids
    Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
    Hope this will resolve this blue access issue.
    You can use another memory stick like 1GB in this camera.
    Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
    Warning in memory "FORMAT ERROR"
    You could try to re-format the stick. Some cameras are a bit picky when it comes to formatting. Often they will not work unless formatted directly on the camera. You could also try formatting it under widows if you have a card reader. This may kick it into life.
    Apr 14, 2008 | Video Cameras
    Sony Cyber-Shot DSC-P32 Digital Camera Logo
    103 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    Are you a Sony Camera Expert? Answer questions, earn points and help others
