Question about Canon PIXMA iP90 InkJet Printer
Printer jam I was trying to print labels and the edge jammed and when I tried to remove it, it came off in the printer, the sticky bit...is there a way to get it out or is this a "doctor" problem? Help, I need to do some printing!!
  • 50 Answers
Hi Printers have been greatly simplified inside, so if you can get it apart, it should be fairly easy to see the problem and remove it. The problem you will likely have doing it yourself, is getting the thing apart. There is normaly a plastic cover over a metal chassis, (although there is more plastic and less metal every year), and there are clips built on the plastic cover that you pry gently with a screwdriver and it pops off. Every model is different, and the manufacturer purposely hides these to make it difficult for consumers to get apart. Also, depending on the model, it may have a switching power supply board inside which can be dangerous, so if you get it apart, make sure it is never plugged in until back together. Fewer shops service printers these days, because the cost has come down, but in cases like yours, we remove the debris and clean them for $35.00, so if you call around, and describe the problem, you may find a shop that will do it, and save you the hassle. Good Luck!
Posted on Jul 26, 2006
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
While printing a label, a sticky label got stuck around the paper feed and in removing it the paper out sensor head came loose. i tried to replace it but I get a paper out light on. Which way up should the...
It sounds like you had a paper jam and when you tried removing it, something from the printer got loose/broken. It would be best to contact Lexmark technical support for assistance.
May 21, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
Paper Jam
You may have left some debris in the printer, or there could be a piece of debris blocking one of the sensors. Try to reinspect printer and clean it out throuroughly. If it still isn't printing, try removing toner and replacing again. If neither of those work buy a used laser printer on craigslist and save yourself the trouble.
sorry if this isn't great news. service may be worth it, try a small computer store rather than a larger store.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA iP90 InkJet Printer Logo
55 people viewed this question
old marine
old marine
