Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
WASHING MACHINE MOTOR HAS A HISSING SOUND AND AGITATOR SPINS LIKE A TOP WHEN I PUSH IT BY HAND
    Scholar:
  • 56 Answers
Jazzy,
Sounds like it might be the drive belt which is worn and stretched beyond the ability of the self tension mechanism. To replace the belt on most top loading washing machines is quite simple and the parts can be gotten from one of many appliance part suppliers.
Steps for replacing the drive belt:
1. Unplug unit from AC
2. Tilt unit back on rear feet. You do not need to lay it completely over, just far enough to get to the belt.
3. Using only your hand you can remove the old belt. Take notice of the condition of the belt. If it has any glazing (shiny coating) on any edge the belt was slipping and most likely the cause of the problem.
4. Wipe all pulley wheels with a clean dry rag to remove any belt dust as this will act like a graphite lube when you install the new belt.
5. Install the new belt around the 3 pulleys (one is for the tub, one for the drive motor and one for the drain pump).
6. Plug the unit back into the AC and check for movement under a spin cycle.
If you still have a problem more than likely your unit is in dire need of a clutch bearing replacement. This is NOT something that most owners can do as there are several specialized tools needed to remove the tub brake mechanism (The brake mechanism is under 200lbs of torque) and attempted removal of the brake mechanism without the compression tool can and will result in bodily injury. This repair should ONLY be performed by a factory trained service tech.
A great place for all types of appliance parts is:
www.appliancepartspros.com
They ship anywhere in the world and for US shipping you can get next day shipping. I usually opt for 2-3 day ground and save the extra cost. This place is almost always the least expensive part supplier that I have used. They have a very detailed website and you can search by model number and find just about any part in less than 5 minutes.
Hope this helps. Cheers.
Keith
Posted on Oct 21, 2008
No spin, sounds like a spinning rachet handle
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Jul 05, 2014 | Amana Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator weak and ineffective
If this is one of the older "Belt" drive machines Id think the belt may be loose. If its a direct drive machine maybe the agitator is stripped? Can you push down on the agitator careful not getting fingers in the agitator vains see if you can stop it from agitating by hand and hear any differance in sound.
Apr 23, 2009 | Washing Machines
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Machine will not agitate or spin. Have replaced broken drive belt but machine only washed one load and now the motor just hums
hello it sounds like you have a frozen motor have you tryed spinning the pully by hand to see if you can spin the motor ? if your able to spin the motor pully by hand and it still is'nt turning when powerd on then your have a bad motor
Apr 05, 2009 | Maytag Performa PAV3200
Washer is making a grinding noise. It want spin or agitate.
sounds like ur shaft is stripped motors about 100 bucks ur call prob better get a new one
Dec 31, 2008 | Kenmore 22422 Top Load Washer
AGITATOR DOESN'T WORK WELL
sounds like the spline is stripped on the agitator take the bolt out of the center of the agitator remove the agitator and visually inspect the splines let me know if this works
Sep 12, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine trouble
it sounds as if your lid switch is out of position. in the past depending on the model i have taped a penny or two to the top of the switch so the plunger makes contact
Jul 21, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
