Question about Neff U1721 Double circotherm Electric Oven
Oven fire, loud explosion sounding like a welding torch,flames. Very nervous!
I purchased a GE top stove oven JBP49BKBB SKU 579-840 in nov 2006 at Home Depot in Portland, OR.
On 10/20/2008 I turned the oven on to 350 to warm up some bread and within 5 minutes I heard a loud bomb-like explosion with big flames coming out the oven door, with a popping noise and a huge, intense, bright light (excedding that of a welding torch). This 'explosive event' lasted under a minute, as we managed to turn off the circuit.  I got very nervous and scared, as I had my 3 year old granddaughter in the kitchen with me, as well as my husband and daughter, who were nearby and witnessed this event. I am afraid to use the oven ! Thanks, Ana Rosa Edgar
What can I do ?
  • 26 Answers
Most likely an element burning out though it does sound a little more excessive than is the usual case. Was the fan oven on, in which case remoce the inner ear panel in the oven and check to see if the element surrounding the fan has burnt out
Posted on Oct 21, 2008
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Feb 23, 2010 | Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
I have a Frigidaire stove, when I turn the oven on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Have you spilt anything on the burner? If so it will need to be cleaned,you will need to do the following (you need a pin, a matchstick, a drinking straw and a torch):
Make sure the oven control and the electric isolated is off please, remove the shelves, using the torch, inspect the oven burner, if there is no apparent blockage, disregard the following advice and seek the help of a 'Gas Safe' engineer in your area.
If it is blocked,using a pin or matchstick clean the holes in the burner, and use the drinking straw to blow the debris away. Move away from the burner, and see if it lights.
If this fails to work it could mean that the ignition is in the incorret position allowing for explosive ignition. See advice from a 'Gas Safe' qualified engineer.
I hope this helps.
Jul 06, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Neff U1721 Double circotherm Electric Oven Logo
384 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
