Question about Amana AGDS902 Gas Kitchen Range
The oven control device
I am trying to install a new oven controll or clock divice, this take's the doing of removig the control panel or the face of the stove off I had allmost all of it off but could not remove the face. This is probably imposible for you to understand what the hell I am talking about? If you can tell me of a web site I can doanlowd a moanual or look at one I would greatly appreaciate it thank you Vincent Ballarano My email is ballaranovincent@gmail.com
  • 84 Answers
What is the model
Posted on Oct 21, 2008
Oven all of a sudden stopped working. The clock face on the upper right hand side of control panel is illuminated and I'm not sure what this is for. Is it related? Do I buy a new oven, or try to fix?
Microwave ovens are not to be messed with. Get an approved Sanyo technician to replace the control panel or ASDA; 29 pounds to replace it.
Oct 22, 2014 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
No sounnd in my divice
After installing the software you will see there is a new audio driver installed in device manager. You have to select that audio driver. Then you will get sound.
Go to Control Panel->Hardware and Sound->Device manager->sound, video and game controller to see the new sound driver.
Feb 22, 2011 | Sony Sound Forge Audio Studio 9
The screen says F7 and an alarm keeps beeping
One of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Oct 25, 2010 | Thermador SC302T Electric Double Oven
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Nov 10, 2008 | Thermador SC272T Electric Double Oven
Electriic oven control broken
maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Aug 27, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Amana AGDS902 Gas Kitchen Range Logo
114 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
