Cannot restore toshiba a200 form recovery disk getting error 23?
  • 5 more comments
  • MTinNeed Oct 22, 2008
    Laptop
    originally hung and I couldn't get it to work. On using recovery disk
    supplied:  Windows loads form the
    Recovery Disk; The 'Recovery Utility Screen' appears with prompt to select
    language, followed by the usual
    WARNING that ..hard disk will be completely erased. OK launches DiskPart
    which sucessfully formatted the volume' - sll so far good.
    This
    is folowed by 'ImageX Tool for Windows' and where things start to go wrong:
    Atter Copyright message:
    "Progress:
    0%
    [Warning]
    . [Read_WIM_header: -> cannot read WIM header]
    [Error:
    23] E:\05241XSP4.swm. [_wim_create_file: -> Fail to read WIM
    header]"
    the
    programme then appears to continue as follows:
    "Progress:
    (and counts 0% to 100% over about 10 minutes) 100%
    [Error:
    1812] C:\Windows\Fonts\mingliub.ttc
    Error
    Restoring image
    The
    specified image file did not contain a resource section.
    ERROR:
    ImageX could not apply VISTA E:\05241XPS.swm Index 2 from ODD to c:\!
    Press
    any key to continue"
    I have replaced the hard drive as suggested on
    one of the Toshiba Forums bur the above occurs exactly the same with a brand
    new drive.
    It’s a Toshiba supplied VISTA Recovery disk that was shipped with the laptop and the machine has a COA key sticker on the underside
  • Anonymous Dec 17, 2008
    I have been advised by PC World to carry out a recovery on my toshiba A210 laptop purchased Dec 2007 due to serious problems with it. I have inserted the supplied recovery disk and it has gone through a number of steps but after progress of around 40% under a heading "Imagex Tool for Windows", the process aborts and gives me the following messages:
    Error restoring image
    The system cannot find the path specified
    ERROR: ImageX could not apply VISAT F:\05249XSP.swm Index 2 from ODD to C:\!
  • jean_peuplus May 21, 2009
    exactly the same pb, here is a "screenshot" of what happens :
    http://www.noelshack.com/voir/130309/Pho...
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    then if the two hard drives are in same condition, then it is either the recovery disk, or something in the bios or memory. how old is this computer?
    is the windows version you are intending to install a certified copy?
    error 23..on the installation or the windows screen?
3 Suggested Answers
  • 97 Answers
SOURCE: error code 10-fc06-002 in toshiba
This is a toshiba error when running recovery discs on your machine. There are two reasons that this could occur, one would be corrupted Recovery Discs and the other is bad hardware (Hard Disk Drive).
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Posted on Sep 17, 2008
  • 44 Answers
SOURCE: Toshiba Satellite L305-S5875; Recovery Error 10-fc12-045d HELP!!
no it is not fried. you just need to find a vista disk and use that instead of the recovery disks. Once you reinstall Vista you should be able to go online for the Toshiba drivers. Make sure you have the windows Vista Key which should be located under the laptop. the vista software install will ask for it.
Posted on Jan 10, 2010
How to repair a satellite toshiba p205-s7806 disk error
Toshiba won't sell you a Factory disk? ODD? If it's a HDD failure or a hardware failure, a Restore/Recovery will not help. If you have Restore turned on, restore to a date before this issue. If you have a Factory Recovery Partition, you can do a System Recovery, keep in mind ALL your data will be lost. You can find a Restore/Recovery procedure here: http://www.ehow.com/how_8012461_toshiba-p205-recovery.html
Apr 19, 2013 | Computers & Internet
Toshiba A60 equiam will not boot from original recovery disk
Try reseating the RAM modules and then try the recovery CD.
If it still fails, take the RAM modules out and take them to your friendly computer repair shop and get them to test the RAM.
Mar 04, 2012 | Toshiba Computers & Internet
Hello, I have a Toshiba laptop A200 - EZ2204X with a model number of PSAF4U now my problem exactly that i have got the recovery discs on a DVDs and after that I have lost them .... and now the windows...
For recovery disks set, they are available only for purchase. You can buy the recovery disks for your laptop on http://recovery-disks.com/toshiba/toshiba-satellite-pro-a200-ez2204x.html.
What I can suggest if you don't want to pay for these disks is to format and install Windows and then you can install free software like Driver detective to know what drivers you will need. Once you have the list of drivers, you can download them from websites like driverguide.com.
Note that formatting your laptop will result in losing everything you have on it.
Hope this helps.
May 19, 2011 | Toshiba Satellite Pro A200-EZ2204X...
I have a Toshiba Satillte L505-S5971 Got something
Your original hard disk may have a recovery partition on it. You may be able to restore the Toshiba to Out of the Box condition, but it will wipe out your data so bach up your data first. For instruction to restore your Toshiba, click on this link and follow my instructions :-
http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Feb 14, 2011 | Toshiba Computers & Internet
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Jan 10, 2010 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
I don,t have recovery disc for toshiba satellite A200
haven't mentioned the os and service pack version
download recovery disc here
http://coblitz.codeen.org/neosmart.net/downloads/guides/Vista_Repair/Vista_Recovery_Disc_x86.iso
burn it a cd using nero or any other image burning software
Jul 09, 2009 | Toshiba Satellite P205-S6287 Notebook PC
I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Recovery Error
Any devices connected to USB ports?
Oct 09, 2007 | Computers & Internet
Computers & Internet Logo
1,420 people viewed this question
David Payne
David Payne
