Question about Toshiba Gigabeat MEG-F20S MP3 Player
Reads syetem error
When i turn it on it reads system error so i tryed to format it but when i plug it in my computer it doesnt registar it
  • 32 Answers
Well, there are two things you should do before taking drastic measures: 1) Turn the batter off for a few minutes, turn it back on and reboot. -or- 2) Try to connect the GB to your PC and re-load the firmware. -Very simply, just connect your GB with the USB cable only to your PC. -Open up Windows Explorer and locate the GB's drive letter (if available, it will look something like this (G:\GIGABEAT - if it isn't there after repeated attempts, skip to the "drastic measure") -Once you locate the drive, keep it in mind and now navigate to the C:\programfiles\Toshiba\Gigabeat Room\2 directory. -In that directory, you'll see a GBSYSTEM directory. Right-click "copy" (or drag 'n drop) it directly into your GB's drive letter and overwrite any existing files. -Unplug, power off and reboot. -If that doesn't work - reformat with the included Toshiba GB format utility and repeat (maybe repeat twice if it fails again - to confirm you did it right.) -If it still doesn't work - time for drastic measures (or taking it back and getting a replacement) DRASTIC MEASURES: ------------------------ Don't worry, it's not that bad and many of us have had to do it for some reason or another. If you're not comfortable taking apart your GB, then please don't do this. Take it back. If you feel confindent in your tinkering skills, follow the instructions EXACTLY as written : So you?re Gigabeat is stalled? Seems like you need to do a little Gigabeat Surgery in the form of a "Hot-Swap". Here?s what?s happening: When you hit the power button, you see the opening Gigabeat screen with status bar. The bar starts to move right like normal, but stops halfway and never moves again, right? So, if you want to fix it yourself? Ok, here?s how. You need to physically reset your drive so the computer will recognize it and you can put an operating system back on it. **This is the ONLY way you'll get it to work** ** DO THE FOLLOWING AT YOUR OWN RISK. ** Here's what you'll need: (not for the "mechanically/technologically challenged") 1) Phillips Screwdriver (smallest you can find) 2) Place to put tiny screws 3) Soft cloth for cushioning 4) Original Software CD (if you don't have it, google ios you're best friend !) 5)Patience **This will work and is not as hard as it seems, risk is minimal as long as you don't remove the front panel!! -------------------------------------------- Ok, here are the steps: (Read all before you start) 1. Go to this site and look up, these are images of the process: http://www.angelfire.com/bug2/gigabeat/ 2. Disconnect the AC adapter and switch the battery to OFF. 3. Only open up the BACK of your GB, leave the front alone, repeat DO NOT REMOVE FRONT!!!(Back slides down a bit, then out - don't force it, you'll bend the metal) 3. *GENTLY* disconnect the HDD according to instructions on the web site. (See below) 4. Connect the USB port on the GB to the computer. 5. Turn battery ON. 6. Wait for GB to error and show USB logo on screen. 7. Re-attach the hard drive WITH THE GB STILL TURNED ON! It's a usb drive so that kind of thing is ok. 8. Go to the GB drive in Windows Explorer and copy the GBSYSTEM folder to the GB as per the instructions in the manual. 9. Safe disconnect the USB device (as per Windows instructions) 10. Turn battery switch OFF. 11. Put your GB back together again. 12. Switch battery to ON. 13. Turn GB on. That should do it! And what is more after you use the library refresh tool in GRoom (select GB not PC in this case) you will have all your music back, too.
Posted on Jun 29, 2007
Syetem error c011ae70
Posted on Jan 17, 2008
Bennyboy,
Thanks for the info. I had the same problem but fixed it with the formatting you suggested
ITS WORKING!!!!!!!!!!!!!!!!!!!
Posted on Oct 18, 2007
Hi, There is something seriously wrong with the proceedure outlined here for the drastic measures.. The gigabeat HDD is and IDE drive with a USB interface. If you unplug or unplug an IDE HDD you will risk damaging the HDD or the controller. The correct proceedure is to turn the power off unplug the HDD turn it on without the HDD plugged in, turn it off again plug the HDD in and then turn the power on. You should not unplug or plug-in the HDD whilst the power is on. You will surely blow up the controller or HDD
Posted on Sep 28, 2007
SOURCE:
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Need system restore files
Try booting it in safe mode. The option pops up when syetem doesnt shut down properly. Can manually be opened by pressing F8. From there, open System Restore.
Aug 11, 2012 | Toshiba Satellite A205-S5814 Notebook
Put a battery in and started the car and the gas gauge doesn't registar or the miles to empty doesnt , trip meter nothing came back it all lighst up but registars 0. how do I get it back???? Thank you
You will need to drive the car for it to calculate the miles, when you remove the battery it looses all memory, try driving a few miles and see if it reads out again. good luck.
Jan 15, 2011 | 1994 Lincoln Town Car
I register for nonoh but my registaration always
hi
call them up or email them your ip might be blocked
http://www.nonoh.net/en/faq.html
Oct 09, 2009 | Computers & Internet
Trouble accessing files on usb
It is probably a driver error on your operating system. I suggest trying a couple different ports- if that doesnt work try a different computer. If that doesnt work most likely your drive file system is damaged and needs to be formatted. Good luck!
Sep 23, 2009 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
My walkman nwd b105f keeps having the 'boot error system shutdown' message on it when i try to turn it on. i tried to format it on my computer but it doesnt read and freezes my whole computer. can anyone...
go to this site. http://www.sony-asia.com/support/download/289419/sectionfirst?subpage=detail. Download the updater and follow the steps mention therein. But before you begin the updating, make sure to back up your file in your Hard Drive. It is easy to select format in the updater first so that it is surely clean then it will automatically update your player. After the update, you can copy your files back again to your player. It works for me, I'm sure it will work for you. (dsgallardo@yahoo.com)
Aug 11, 2009 | Sony NWZ-B103FBLK MP3 Player
Error IPL on the Cash registar XE-A213
remove the Battery. Set the key in the PGM-Position and then plug the power cord.
Wait for the message "No Battery" and insert the batteries (with Poer On).
HTH Alex
Mar 10, 2009 | Sharp Computers & Internet
SD/TF card error..
to format the card is pretty simple really, all you have to do is:-
make sure your card is plugged in with the p.c same as you drag and drop
go to my computer
look for where your flash drive is
dont click into it, right click it
a little list will show
go to format
then click start (dont use quick format)
May 11, 2008 | Nintendo DS Lite Console
Boot error! please format unit
It might be cause by a corrupt firmware. You need to have a utility that restore the mp3 player to its original setting. i had exactly the same problem with my ipod shuffle 1st generation 2 years ago. Good thing Apple has that utility for me to download and until no it is still working. Try to visit and upgrade the firmware using this link for you mp3 player http://support.rcaaudiovideo.com/downloads.aspx?product=192
Please Rate Appropriately Thanks!
Jan 14, 2008 | RCA OPAL M4001 MP3 Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
Toshiba Gigabeat MEG-F20S MP3 Player Logo
1,513 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
