I have a 50dx018 hitachi projestion tv,,its about 10 yrs old....thought the left speaker was shot on it ,checked it out and had no voltege going to it ,so i jumped it over to the right speaker,,works fine...no problem now is the screen starts to flicker at times now..i can smack the tv afew times and it will clear up..may be fine for a dat or 2 and starts doin it again ,,,,,,,,,,,,im thinkin main board in it..havent tore into it yet
techman
  • 3130 Answers
SOURCE: HELP! Fire Hazzard!
It sounds like your focus/screen block, the flyback transformer, or maybe a CRT anode lead is leaking high voltage. This could be a serious problem, or could be a simple one. You should not attempt this repair unless you know all of the high voltage safety issues involved with this TV set. Good Luck
Posted on Jun 20, 2007
SOURCE: lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Posted on Nov 28, 2007
ctf1800
  • 4402 Answers
SOURCE: Hitachi 52" picture started jumping or flickering, now doesn't want to stay on whey you power it on it goes right back off?
do you have a model number?
Posted on Jan 08, 2008
ctf1800
  • 4402 Answers
SOURCE: projection tv - Hitachi
sounds like you need to do convergence.
Posted on Feb 21, 2008
roety
  • 585 Answers
SOURCE: tv suddenly started being blurry with red double
You need the convergence ICs replaced they are soldered in so its very technical , a repair shop will charge between $230 and $400 to replace them. you can try the autofocus or manual adjustments, but probably need the ICs and possibly a few resistors too.
(2)STK392-110 or kit # X480293 comes with 2 ICs and some resistors
gd lk
Eric
Posted on Aug 26, 2009
I have a Hitachi 26" L26DP04UC tv, it is about 5-6 yrs old. The sound used to be fine on about 16 but now have to put it up to 25 to hear it properly. (I am not going deaf) What could be causing this.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 14, 2017 | Hitachi Televison & Video
Was watching hitachi 60" rear projection tv...then it "popped" and won't go on...tv 10 yrs old....neverr a problem ...worth trying to fix??
yes there is a fuse on the bottom left ( think that is whewre it is on this model) but as its near the HT it might be better to let the techs go there If they get eloectrocuted you just call an ambulance If you get fried someone may not find you for a wekk or two good luck
Aug 13, 2009 | Televison & Video
We have a blue spot just below center, not extremely annoying just there. Light engine was replaced 2 1/2 yrs after tv bought. TV only 3-4 yrs old. Thanks for any help.
This blue is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Aug 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
External speakers
Enter your TV model number in Hitachi Manual page and find required user manual.
Oct 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
43FDX01B convergence
Maybe you don't require a new one; take a look at this procedure:
http://zeroization.com/hitachi-43fxd01b-covergence-adjust/
It's worth shot at that price-
May 26, 2008 | Hitachi 43FDX01B TV
HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Jan 08, 2008 | Hitachi Televison & Video
Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ? If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit. If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
Jan 21, 2007 | Hitachi C25-RF35S 25" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
