Question about Linksys Wireless-G Broadband Router
Linksys wireless connection to xbox 360
I have lost the disc for my linksys WRT3OON AND MY XBOX 360 willnot connect as i have to allow connection throgh the router can can i access the router without a disc
  • shizzle123 Oct 21, 2008
    very very helpfull but i think my brother changes name annd password so as long as he remebers that i should b ok thanks for all your help
    Tom
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    not usually..but linksys.com would have those drivers, you know..
    Sergeant:
  • 359 Answers
Goto your computer and click on start, the goto run, then type in ipconfig at the command prompt.
Write down the GATEWAY ip address as this is the Linksys router ip.
Now open up Internet explorer and type in the GATEWAY ip that you just wrote down.
You will be prompted with a username and pw screen/box. Factory default username is admin with pw is just blank(not the word blank but just nothing entered as the pw), or admin as the pw.
If you're lucky you should be able to manually configure the router without the config cd. If not, I have had this issue before and you will have to contact linksys for a replcement CD as some routers do require install cd since manual setup just doesn't work for some reason.
Posted on Oct 21, 2008
  • Daniel Jenkins
    Daniel Jenkins Oct 21, 2008
    Next time get a belkin router since they don't need install cds
  • Daniel Jenkins
    Daniel Jenkins Oct 22, 2008
    You can reset router to factory defualts by getting a paperclip and pusshing the small button located on the back of the unit for about 10 secs.
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    How to connect to xbox live with linksys router
    Just to confirm you are using a wireless connection to hook up to the router? do you have the router model number? Have you configured the correct wireless settings on the 360? Make sure that if you have a key that you have entered it correctly. http://support.xbox.com/support/en/us/xbox/xboxlive/getconnected/setupahomenetwork/stepbystep.aspx
    also you can use the xbox support site for reference, use the left side panel to look at wireless settings and other help.
    Thank you,
    Lee
    Oct 21, 2009 | Microsoft Wireless Network Adapter Xbox...
    How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
    The easiest way to connect to Xbox Live without using your pc is to buy a
    wireless network adapter for your Xbox.
    You would then go into the system settings on the Xbox and configure the settings for your wireless network.
    http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
    Xbox 360 - direct to internet - No PC.
    Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
    Linksys dual-band wireless-n gaming adapter + westell versalink
    put all the adresses and getways(on xbox internet setings same as pc then it should work
    Mar 25, 2009 | Linksys Dual-Band Wireless-N Gaming...
    I have a linksys usb wireless adpater can I use that to connect
    Sorry only official microsoft products are able to connect to Xbox Live wirelessly. So far the Wireless adapter is the only product available
    Jan 25, 2009 | Microsoft Wireless Network Adapter Xbox...
    My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
    hi,
    in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
    for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
    Dec 29, 2008 | Linksys WRT160N Wireless Router
    Opening the NAT connection for Xbox 360 working through 2 routers
    1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
    2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
    3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
    Hope this helps!
    Nov 15, 2008 | Computers & Internet
    Xbox 360 live on wireless router
    In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
    Nov 09, 2008 | Microsoft Xbox 360 Console
    Xbox 360 to Linksys wireless modem...
    OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
    Where going to use the default IP addres for an easier setup.
    First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
    Aug 22, 2008 | Microsoft Xbox 360 Console
    Linksys wireless adapter
    I don't believe so. Unfortunately, Microsoft built the OS in the XBOX 360 to only work with their hardware -- that includes the wireless adapter. Try a wireless bridge instead like the Linksys WGA54G.
    Hope this helps!
    Jan 30, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
    Linksys Wireless-G Broadband Router Logo
    79 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
