HELP! Random BSOD!
For no Apparent reason my computer is getting random windows BSOD's for no reason! it just stops saying stop 000x000000007f (i think, it's too fast.) I have no idea what i have done recently except install Vista SP1 but i dont think thats it! Help please!
  • 1 more comment
  • Spaceweed Oct 23, 2008
    Hey thanks for trying guys but i have done all of that already and to no avail. All system hardware is perfectly fine, so the only option left is to reformat the hard drive, luckily I´m able to to access Vista (heap of ****) so i can save my important files :(
  • Canaan Hoffman
    Canaan Hoffman May 11, 2010
    if u can run post your Memory Dump:
    If your computer is bootable, you can set Windows NT to create a memory
    dump file when a Blue Screen of Death occurs. To do so, open the System
    Properties dialog box from Control Panel and go to the Startup/Shutdown
    tab. Keep in mind that
    the partition where you store the memory dump file must have at least
    enough free space to store your page file, plus your physical RAM
    space, plus 1 MB. For example, if your machine has 128 MB of RAM, the
    partition must have enough free space for the page file, plus an extra
    129 MB.
    then i can diagnose the problem
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..have you run a tune up
    disk clean
    defrag
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
I did some research on your error
and if its the 0x0000007f u say it is then this is why is BSOD-ing
- Your computer has hardware or software problems (hardware failure is the most common cause).
- You try to over clock the speed of your computer's processor (for example, you set a 150 MhZ
processor to run at 187 MhZ).
The above STOP error means a trap occurred in kernel mode and the trap is either one the kernel is not allowed to have or is always fatal. The most common causes of a STOP 0x7F are:
- Low-level hardware corruption, such as corrupt memory (RAM)
- Mismatched memory modules
- A malfunctioning motherboard
Solutions:
- If either software or hardware can cause a particular trap, a debug is required to determine which is the cause. If you suspect a hardware problem, try the following hardware troubleshooting steps:
1. Test the RAM in the computer by running the diagnostic software that is provided by the computer manufacturer. Replace any RAM that is reported as bad. Also, make sure that all the RAM in the computer is the same speed.
2. Try removing or swapping out controllers, cards, or other peripherals.
3. Try a different motherboard on the computer.
- If you are over clocking the speed of your processor, set it back to the speed at which it is designed to run.
- Check with the hardware vendor for any updated hardware drivers or BIOS updates, or both.
Posted on Oct 21, 2008
My computer says stop: 0x00000024 (0x00190203,0x86f6e330,0xc0000102,0x00000000) `
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.:
1) Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:Startup using Last Known Good Configuration to undo recent registry and driver changes.Use System Restore to undo recent system changes.Roll Back device driver to version prior to your driver update.
2) Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
3) Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
4) Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default.
Non-default hardware settings have been known to cause a Blue Screen of Death.
5) Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
6) Use Reginout to fix BSOD stop errors
Apr 17, 2012 | Dell Inspiron 6400 Notebook
Blue screen
Check the size of Random Access Memory (RAM) in your computer. Its small size could be the reason for this problem as many of today's software need large amount of memory to operate in smooth manner. Additional RAM will also increase the efficiency of your computing particularly for gaming.
• Excessive use of computer or a malfunctioning cooling system can make computer/laptop overheated. Whenever system is heated, its efficiency will go down. BSOD is one possible consequence of over heated system. Keep fan of your computer in fully functional mode.
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner reg ion out and PC optimizer
Sep 25, 2010 | Microsoft Windows Vista Business Edition...
Hey do you guys know any tech does work voluntary to fix blue screen problem
3 Easy Tactics on How to Fix Blue Screen of Death The famous windows Blue Screen of Death(BSOD Error) can be fixed with 3 types of Blue Screen Death Repair. Try to apply the following tactics when the blue screen death occur before you call a computer expert for help.
1. Uninstall any programs which you had installed recently.
Sometimes, there exists a conflict in drivers installed on your pc that causes the blue screen error to pop up. In most cases, this does not occur, but if it does, Windows offers you a roll back feature where you possibly can bring your PC’s operating system back to its original functioning state.
2. Random Access Memory is faulty.
When the Random Access Memory is faulty, the Computer stops functioning everytime when the RAM is accessed by the CPU. This brings about your PC to halt almost at Random. A simple solution is just to remove 1 stick of RAM and see if the problem goes away. If it does, your PC is fixed!
3. Repair Registry Errors to fix the blue screen of death
Over time, the registry of your windows will get messy with tons of data because you always install and uninstall programs or applications. When you experience slow performance in your PC during boot up times, opening up of new files, surfing internet and blue screen of death, its likely that your registry has a ton of information which needs to wade through. Therefore, it is highly recommended to get a good registry cleaner and improve the performance speed of your PC. Errors fixed in your registry can also fix Blue screen of death error instantly.
Sep 11, 2010 | Computers & Internet
Blue screen error ?
Sep 09, 2010 | Microsoft Windows XP Professional
Volume pop-up
may be the volume up button is jammed in the pressed position....just try pressing it and try releasing it from the current position....
May 04, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Monitor goes into sleep mode at random
Check your power options in your control panel - default is usually 20 minutes to put monitor to sleep - you can adjust the time there. The monitor itself does not usually have this as a function so I would start there first.
Mar 25, 2010 | HP w1907 LCD Monitor
BSOD at start of Windows XP Setup
try F8 to got to the startup menu, and choose last known good configuration, use a ps2 keyboard or an adaptor and nothing that needs the USB.SYS Driver to function, and you should be able to reinstall Windows, if last known good configuration doesn't work, i hope this helps, please give good rating
Apr 30, 2009 | Computers & Internet
BSOD- STOP error message
most bios updates are found on the compaq website, they need to usually uncompress to a 3.5 floppy or they are auto-installing programs u get from the website, your issue however sounds to me more like a corrupted version of windows, did you try a fresh installation with the recovery cds or master disks?
Aug 12, 2008 | Intel Motherboard
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
