screen has turned a nice shade of blue. use auto config but set and then immediately goes back. tried swapping graphics cards but no help. tried the posted solution but shaking the cable did not help.
Comments:
Jul 27, 2006
- Just to add. The tech's final note that it is probably the monitor looks correct. I hooked up a cloned monitor and the colors are correct on the clone - which seems to tell me that it is the monitor.
-   My screen always lose it's red color after It's been on for a while. Occasionally it will switch back on and off again. It generally goes back to normal if I restart the computer and give it a rest.
-   Guest
Oct 07, 2008
-   I have this issue as well, I tried to mess with the contrast and brightness that didn't do anything. I did see the color flash back to normal twice but screen seems to be stuck in the bluish tone.-   rusbro
is it a greenish blue?..... if so you have lost your red signal..... check your monitor connectors for bent or broken pins...... usually happens after swapping cables or monitors on a computer..... you could also have a bad cable or monitor.....
is the monitor a CRT or a flat panel.... loss of one color is very common on CRT monitors, and could be a bad solder connection on the CRT driver board, or a bad video chip..... flat panel LCD monitors don't usually lose a color, although it is possible.... the most common failures on LCD flat panels is total power supply failure (no power at all) or display matrix driver failure (colored stripes across or down the screen), but a cable failure is also possible, like i said above, check the connectors for bent or broken pins..... there are 3 rows of pins...... at the widest side of the connector, there should be at least 3 pins next to each other on that row (sometimes there are 5), the middle row should at least have 3 consecutive pins as well (and again, there are sometimes 5) the last row (the smaller side of the connector) should have at least two (but sometimes all 5) pins in it. the first row and last row of pins should line up vertically, and the middle row is offset a half a space, so from top to bottom, the columns of pins make a zigzag...... if the connectors are alright, then your most likely problem is the monitor..... if another monitor works on the computer, it's the monitor..... if another monitor has the same problem on this computer, then it is the video card (or the motherboard's video output, which is fixable by installing a video card)
proview 700p has good blend or proper colors except black but any black background or writing goes...
(More)
proview 700p has good blend or proper colors except black but any black background or writing goes to a greenish colored lines
when booting the pc, this has to be done soon after the monitor has gone to standby other wise it...
(More)
when booting the pc, this has to be done soon after the monitor has gone to standby other wise it never comes on
I unpluged my monitor to plug it into my laptop when I pluged my monitor back into my desktop (still...
(More)
I unpluged my monitor to plug it into my laptop when I pluged my monitor back into my desktop (still on) the screen was blueish and when I pressed the menu button to check the settings the brightness and contrast were up in the 500s but usualy only goes to 100 and when i altered then they went down the bar again and again but wouldnt go up. now when i auto config it looks right for a split second then goes funny again. please help
