Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
While the dryer is in the auto dry mode it won;t shut off even when the clothes are dry
  • Anonymous Mar 16, 2014
    Moisture in dryer and it won't dry clothes
  • 4 Answers
Sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
Jan 11, 2017 | Maytag Dryers
My Maytag MDG6400AWW timer does not advance in the Auto mode. The clothes will dry but it will spin and spin for hours until you open the door. In timer mode everything appears to work normally
sounds like it is not sensing the temperature, which is the thermostat, here is a website that will help you out, #6 dryers basic, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 27, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer wont shut off
Is it an auto sensor shut off? If so, it may be that your hose is plugged and so actually takes that long to dry the clothes.
Mar 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My atlantis MDE7600ayw is taking two cyles to dry
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Jan 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
Dec 01, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,529 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
