Wireless access on ASUS Eee PC
When trying to set up the wireless connection on this PC it shows the wireless networks around. When you ty to log into one with the correct password (even from only inches away) it sticks at "PENDING" for ever.. There is an aditional box not shown in the instruction book on the "ENCRYPTION INFORMATION box which is called "KEY INDEX". Does this play a part?
  • alan100 Oct 22, 2008
    Thank you for the suggestion but in all cases the wireless connection has been turned on.
    I still want to know what the extra button called KEY INDEX is for and how it affects it.
    Problem Solver:
  • 16 Answers
Did you make sure that when you go to the control panel on the computer that your settings arnt set so that wireless internet connection is turned off! This happened to me once! I could see the connections, but I couldnt connect to them!
Posted on Oct 21, 2008
  • skycam37 Jan 18, 2011
    I have a similar problem, which comes up only with encrypted connections. (With unencrypted routers, my eeepc 701 works fine.)
    I find that if try to reconnect to connection after it has worked OK once, the eeepc asks again whether the encryption is WPA or WEP and what key index I want. Then after I supply the password, the dread "Pending ..." message appears. For God's sake, all I want to do is log on. I don't care about a key index -- whatever that is. And isn't the computer smart enough to know whether to use WEP vs WPA?
To whom can help, The wireless is not working on my ASUS Eee PC 1000HA. It's working on every other laptop in my house so, it is turned on, it's just not working on my Eee PC 1000HA. Thank you, Dr.M.Seus
Right click the wireless icon in the lower right hand corner by your clock and click view available wireless networks. Then select configure advanced settings. Click on the wireless networks tab.
In the lower part of the screen select your wireless network and remove it. Reboot the laptop
Once back on, view available wireless networks again, double click yours and join it again. It may ask you for your password so make sure you have that handy.
Mar 01, 2011 | ASUS Eee PC 1000HA Notebook
Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Sep 01, 2009 | ASUS Eee 4G Notebook
Get ''pending'' for ever when trying to connect to wireless AP. Log says can't set wireless frequency - operation not supported and then DHCPDISCOVER never gets an answer. If I use static IP simply get...
I had a similar problem. Hit "Fn"+"F2" to cycle the wireless off then on again. Allow about 30-60 seconds to get IP and DNS info from the access point.
Then, using the network adaptor icon in the utility bar (on the bottom right), right click, select "all network connections". Click each network adaptor and from the "Connection Tab" Disconnect each adaptor. Then restart the wireless adaptor with the "Connect" from the "Connection Tab".
I'm assuming that there are no funny settings in the Properties which are preconfiguring the adaptor for a previous connection. If so remove any present values. Leave the connection set as DHCP as this is teh most common way that adaptors will get their settings from teh access point your attempting to connect to. Cheers.
Jul 10, 2009 | ASUS Eee PC 701SD
ASUS EEE PC w/ Windows XP will not Connect Wirelessly
You need to know if your home network requires a password or paraphrase to allow you to connect. Also, you might have to check your settings on your router, they have to match the settings of your laptop wireless adaptor. You can try these solutions and if no luck post with more information
Jul 03, 2009 | ASUS Eee PC 900 Notebook
Wireless network is locked asus eee pc 4gsurf. On Wireless Networks - Visible Access points (window) at the left hand side of Netwok name a picture of a locked lock appears. How can I unlock the lock.
When you see those locks it means the wireless connection is a secured connection. You must have the access code to connect to this network. If you see a network without the lock, you can access it without a code. Good luck.
Jul 01, 2009 | ASUS Eee PC 4G (90OA01A20102111U305Q)...
Asus eee PC 900 wireless access points
You should be using one access point and have repeaters to give you wider wireless coverage,
Jun 22, 2009 | ASUS Eee PC 900 Notebook
Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
Jan 04, 2009 | ASUS Eee 4G Notebook
Wireless connection
Some ideas...
I found that sometimes I have to "disable" the wireless service, and then "re-enable" wireless before it will show available wireless connections.
After that, just use your normal connection settings - passwords, security type, etc.
As well, at times, if I use the "Wireless Connections" Icon in the "Internet" page to log in, I have to re-type the password in. If I use the "Network Connections" icon in the toolbar at bottom, it seems to remember my password and logs in faster.
Linux quirks? I dunno. Hope this helps.
Edwin
Nov 20, 2008 | ASUS Eee 4G Notebook
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
513 people viewed this question
David Payne
David Payne
