Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Bissell bagless sweeper sucks up dirt but will not put dirt in the canister cup. It will pickup until it clogs, then it will stop picking up dirt. It will really hold quite a bit of dirt before it stops completely up. Thanks for any help.
  • 4 more comments
  • Anonymous Dec 01, 2008
    Dirt isn't going into canister. But does seem to get picked up.
  • emmanuel speed Dec 11, 2008
    i cleaned my bissell vacuum and re-assembled it but now when i vacuum it seems to work fine but does not deposit dirt in the bagless canister, plz i need assistance TNX!
  • krystal_k2 Jan 25, 2009
    I have the same exact problem. Everything get clogged up, then it just blows it out the back.
  • Anonymous Feb 03, 2009
    Same Problem. Dirt will not go into the cannister and if you take the hose off the dirt just blows in your face. Please help!
  • tattoo_artis Mar 19, 2009
    The same thing is happening to my bissell bagless. its always really messy too. im just going to get a new vacuum myself but one with a bag. i hate these so called bagless pices of junk.
  • Anonymous Mar 14, 2014
    bissell bagless vacuum dirt clogs in hose
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Posted on Dec 08, 2008
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
My dirt devil easy lite cyclonic does not suck up the dirt or anything on the floor anymore the rollers still roll. It stop sucking. [fixyavid=0_l7vneo7w]
check and make sure that the pickup tube from the bottom of the sweeper to the waste cup does not have a clog anywhere you can use a metal coat hanger and straighten it out and carefully run that thru.
Feb 24, 2013 | Vacuums
Vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Not sucking the dirt.
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
heatman101
May 20, 2010 | Panasonic MC-V9620 Canister Vacuum
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Bissell cleanview bagless - dirt doesn't end up in container
i have a bissell power brush shampoo cleaner, it will not release the soap. what is the problem
Feb 20, 2009 | Bissell Cleanview Powertrak 35933 Bagless...
Bissell powerforce bagless upright vacuum 6582
Check your filter. Sounds like it is not receiving enough suction to pull up the debris. If your filters are clean and there are no clogs, disconnect hose from back by the tank and see if you have suction straight out of the whole.
Dec 11, 2008 | Bissell Vacuums
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
238 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
