Question about Royal 10X Shredder
Paper shredder not working
Got some paper stuck on the paper shredder there's no paper in there any more but shredder won't shred any other paper
  • fburnett Mar 20, 2009
    I put is in reverse and it stopped. now it will not work at all. the switchlight comes on for a second then goes out
  • Anonymous Mar 27, 2014
    Shredder does not run continuously, runs when you turn on but stops before paper is all the way thru
Perhaps the basket is not in properly. This has happened to me.....
Posted on Apr 04, 2009
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Does not shredder middle of paper
First, make sure you turn your power to the shredder off. Take off the top of the shredder and turn it over. Is there paper stuck between the shredding wheels? I had to carefully pull this paper out with a set of tweezers. Be careful, as the shredding wheels are very very sharp!
Good luck,
Paul
Apr 11, 2015 | Shredder Office Equipment & Supplies
My kobra shredder won' shred when we put paper in lights are on
Is the discharge at the bottom where the shredded paper comes out clear? If its blocked by paper etc, it will not shredd.
Aug 19, 2014 | Office Equipment & Supplies
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
My shredder won't shred paper. It sounds like something is stuck / locked. I removed any paper shred and still nothing.
IF you've had that shredder for any longer than 4 years its about time to trash it. And some models of shredders actually can't shred anything thicker than normal notebook paper, even after about a year. Make sure you haven't
Apr 25, 2011 | Memorex Office Equipment & Supplies
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Paper getting stuck once shredded
As a test try shredding into a small box or even the cabinet itself with the bag holder and bag removed. Just to see if these are causing the problem.
The bag Full switch is activated by an arm which is pushed up by the pressure of the shredded paper in the bag as it fills.
When a sheet of paper is shredded, after the trail end of the paper goes past the "eyes" the machine should still continue to run on for a few seconds to drive the shredded paper out.
May 13, 2010 | Elcoman Kobra 300 SS4 Shredder
Shredders on but is not working?!
you need to make sure that the paper detection sensor is not stuck or full of paper dust.....
May 18, 2009 | Fellowes 3011001 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Royal 10X Shredder Logo
445 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
