Question about RCA D52W19 52" Rear Projection Television
Power comes on and sometimes works fine, and sometimes it will stay on for a few seconds and then shuts off, other times it will come on, go off by itself and then come on again by itself and finnally shut itself off.
    Sergeant:
    Champion:
  • 227 Answers
Check the horizontal board (sweep) for loose connections or you might find some bad caps in the same board
good luck
caypianan@yahoo.com
Posted on Oct 21, 2008
Hi, I have a Goodman furnace model GKS91155DXAD. The blower stays on. After turning power off for a few minutes then back on, the draft blower comes on for a few seconds then goes out but the blower...
I would check hot surface ignitor or spark ignitor to make sure they are working. If not then replace them and try again.If ignitor does not come on control board will shut down, try to restart usually try 4-5 times then lock. out. Generally for a preset time then try again. If it has tried to start to many times and failed it will lockout until power is shut off and it can reset. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Hard to get tv to stay on. comes on then shuts right off??
I have a very similar problem with my same tv. I know you posted this a while ago but if u solved your problem I would love to know how to fix it, mine just went out with that same problem. And vice versa if I get mine fixed.
May 15, 2010 | Toshiba 65H84 65" Rear Projection HDTV
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
Mar 07, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
1993 Ford Ranger Headlights won't stay on
you will probably find the problem stated with a poor connection in the headlight switch plug and is now heating up and looseing conection in a short time.remove the headlight switch and you will see what i mean.
Jul 29, 2009 | 1993 Ford Ranger SuperCab
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
May 12, 2009 | Kenmore Dryers
POWER LIGHT STAYS ON ALL THE TIME ON CRAIG CDV 327
The manual states that one needs to unplug the unit when not in use.
Dec 03, 2008 | Craig 731398403288
SCREEN WILL NOT COME ON
Could be a few things. Bad bulb? Just like anything, some are just not made correctly. Could be the ballast that powers the light, or you may have a component on any board that is failing causing it to go into a protection mode.
Apr 02, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
