Question about Symbol MC9060-G
MC9060-G stuck in IPL (initial program loader mode.
I have the MC9060-G handheld barcode scanner and the screen displays the initial program loader (IPL) menu and nothing more. Selecting system reset returns the unit to IPL mode. I have the unit in a symbol docking station, and my Windows XP computer cannot see the docking station. I would like to keep what remaining hair I have left, so if there is anyone who can help me with this issue I'd greatly appreciate it.
The scanner was previously working fine; it was returned to IT in IPL mode. Removing the battery for several days and replacing with a fresh battery only sends the system back to IPL mode. I'm guessing that the system has lost it's mind and needs to be reloaded, however, my pc cannot see the unit in the docking station.
  • Anonymous Oct 30, 2008
    The same.
  • rearl306 May 11, 2010
    What version of Windows XP are you using? Are you using ActiveSync to connect to the cradle?
Windows Active Sync will not recognise a scanner in IPL mode. You need to install the Symbol Device Configuration Package that is applicable to your scanner/cradle. Once installed and configured you can use SDCP to restore the Hex files needed for basic operation. All the files and loader software can be found at
Good Luck
Posted on Nov 28, 2008
    New Friend:
I tryed to reinstall OS on Motorola MC9090 via TCM utility. Unfortunatly i mixed the right pattern of HEX files and now the terminal is not able to boot even in IPL mode. Just a "brick". Is there any way to fix to this problem, or this device is no longer repairable without Motorola service?
Posted on Sep 12, 2013
  • Yuriy
    Yuriy Apr 24, 2014
    Patifon007, have you restored the terminal? I got the same problem.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
That's right it has nothing to do what OS your PC has.. it will not recognise the scanner unless you downloaded the symbol configuration i believe, TCM once downloaded you will need a cleanboot file from symbol website according to your MC9000 series model.. the step is quite simple... first release battery half way then press trigger and power button at the same time, then push the battery in do not let go of the trigger and power once IPL Mode display on your scanner screen release power button, but do not let go of the trigger, docked the scanner onto cradle the release trigger, open TCM program by then all necessary drivers for your mobile scanner must be installed onto PC.. navigate up and down arrow to partition on your scanner the select, go to your pc browse the PT file and drop down arrow select symbol usb then download, follow this process to remaining file like the next file would be.. Application,Platform,OS,Monitor once the last step is done the scanner will boot up to factory default.... there you go.. have fun...
Posted on Sep 12, 2009
How to activate the download IPL of IPLBootROM.
We recommend you contact Motorola Solutions Support
portal motorolasolutions com
Motorola Mobility Support
Jun 10, 2014 | Zebra Symbol Technologies MC909X-G Series...
How to enter the scanner SYMBOL MC9090 boot loader in the IPL (Initial Program loader). What you need to press or do to start downloading bootloader IPL.
you run IPL with a cold boot
  1. Press the primary battery release on the mobile computer to partially eject the battery from the mobile computer.
  2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and the Power button.
  3. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is fully inserted.
  4. The mobile computer initializes.
May 20, 2014 | Symbol MC9090 Barcode Scanner
The application, can be configured to read the barcode. There is an application on the scanner it will tell you what the barcode actually is. either Scanwedge or Scan both should be in the Sample applications, or from the desktop click on "Olt"
Aug 20, 2013 | Symbol MC9090-G RFID Handheld Barcode...
The display screen does not light up. You can see and use the icons.
1) The power supply for screen starting to fail 2) You must go to the repair shop
God bless you
May 09, 2012 | Zebra MC9060-G Handheld Barcode Scanner
How to fix the symbol if there is initial program loader ?
You will need the Hex file for that device and the Motorola USB Download tool.
Jan 12, 2012 | Symbol Motorola MC3090 Handheld Computer
Mc9060 no sound: in setting i set it to the high volume setting - enter - then check it is back to the lowest setting- not holding change in settings
you need to connect the handheld to your PC and then use software to change settings for the device. There is no other way for the settings to persist a cold boot.
Mar 17, 2011 | Symbol MC9060 Barcode Scanner
How To Reformat my MC9060-G !?
If you have access to your MC9060 handheld SD card (below keyboard), download and unzip from 0 189012464 to the root directory on SD card, Full charge the battery, and run OSupdate.lnk, 4 - 6 minutes and Voal?!!! fresh and updated WM2003 OS............
Nov 08, 2009 | Symbol MC9060 Barcode Scanner
IPL Flashing screen will not come up. Flashing now impossible?
Unit is stuck in IPL mode, you need to completely reload this unit, I can help You can always contact me by phone or email 630-622-2024 Please visit our website
Oct 14, 2009 | Symbol MC9060-G
Screen in Landscape mode
Jan 26, 2009 | Symbol MC9060
Symbol MC9060-G Logo
8,153 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
