BLACK LINE DOWN DOW PAPER
WHEN I PRINT THER IS A BLACK LINE DOWN THE WHOLE PAGE
    Scholar:
  • 56 Answers
If this problem is on a laser printer there is only one thing causing the issue.
More than likely there is a permanent scratch in the surface of the image drum that goes all the way around the cylinder.
To verify this simply remove the toner cartridge from the unit and turn it over. You should see a small plastic shutter mechanism which is covering the photosensitive drum. Carefully open the cover without touching the drum surface with your fingers as the oils on your skin will damage the drum surface further. If you see a mark in the drum surface, that is your problem and the toner/drum unit will need to be replaced. This most likely was caused by something that was accidentally introduced into the imaging area of the unit. Before putting a new toner/drum cartridge into your printer verify that there are no obstructions like a paperclip or even smaller a staple as this will get caught in the new unit and cause the same problem. This problem is not covered by manufacture warranty and therefore you will need to bit the bullet and buy a new one.
Hope this helps solve your problem. I used to work as a Systems Engineer for Kyocera-Mita a printer and copier manufacturer so I have seen this issue hundreds of times over the past 20 years.
Cheers,
Keith
Posted on Oct 21, 2008
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
Black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Nov 05, 2007 | HP Photosmart C6180 All-In-One InkJet...
765 people viewed this question
k24674
jasbo
jasbo
