Question about Compaq Presario Notebook
Windows xp home edition startup problem
Upon startup a black screen appears with & commands at the bottom. The next screen is black with a curser at the top accompanied by a high pitched alarm type noise. After a few seconds windows advanced options menu appears asking you to select an option.
Safe mode
safe mode with networking
safe mode with command prompt
Enable boot logging
Enable VGA mode
Last known good configuration
Directory services restore mode
Debugging mode
Disable automatic restart on system failure
Start windows normally (high-lighted)
Reboot
Return to OS choices menu
Clicking on start windows normally, the next screen asks you to choose an option which is:
Microsoft windows xp home edition. Clicking this option everything starts up normally.
I thought it might be a virus that caused this to happen, so I did a destructive restore and brought the computer back to out of the box condition. This didn't make any difference.
Thanking you in advance
Sally Wilson
Sallywilson@xtra.co.nz
  • Salwils Oct 21, 2008
    Thank you for replying. I will try your suggestion of returning the bios to factory defaults.
  • Compaq Master
  • 5,568 Answers
One of these; Esc & F10, will give you access to the BIOS settings that are stored in a bit of memory (CMOS) that the system reads at turn-on.
You will get a text-only screen with a number of function selections which can vary widely so look at them all without making any changes (arrow keys and Enter selects) to see if the feature that is causing you to choose at every boot is a BIOS setting.
All BIOS seem to offer a 'Save and exit' or a 'Exit without saving changes' type of choice so if you find none that logically could be altered to avoid going through those menus each time, you can return to your undesired condition without messing up anything.
Also typically present in BIOS is a choice that read something like 'Return to factory defaults' which will automatically change the setup to something safe and that which most users want. If you choose that one, then you need to choose the 'Save and exit' selection.
The reason for those steps is to allow those who use a Unix-based (or other) alternative operating system for some tasks to choose different boot modes.
Posted on Oct 21, 2008
My lenovo s10-3 has turned a black screen after i go to system restore
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 25, 2012 | Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
Try running the check disk utility.
May 21, 2012 | Toshiba Computers & Internet
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
Apr 25, 2012 | Computers & Internet
Windows XP Home Boots midway and screen go black.
Follow the tips below to fix the problem:
  • Scan PC for Viruses
  • Clean Registry
  • Run Last Known Good Configuration
  • Repair Windows
Mostly professionals recommend Intel Partner Software, RegInOut System Utilities to fix the Windows boots to black screen problem.
Dec 27, 2011 | Microsoft Windows XP Home Edition
My xp pro os wont boot after running chkdisk at startup.. It checks the disk says ''clean'' then acts like it is going to boot up windows but just hangs there indefinitely .. tried safe mode and it hands...
Open XP in safe mode with command prompt.
Open a command window (start/run type cmd in the box then enter) and you will get the following.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
You will then have a flasihg curser after
C:\Documents and Settings\PC name>
Type
CHKDSK /f /r
You will then get
C:\Documents and Settings\PC name>chkdsk /f /r
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N) y
This volume will be checked the next time the system restarts.
Type exit and restart.
make sure there is a space between each / and the previos word/command
The /f and /r do the following
/f: Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
/r: Locates bad sectors and recovers readable information. Again the disk must be locked.
Jul 30, 2010 | Microsoft Windows XP Professional SP3 Full...
Black screen startup
is it regarding to your desktop screen all black(black desktop)?
then it might be a genuine OS issue. to fix that you should enter a valid license. hope this help.
Feb 17, 2010 | Microsoft Windows XP Home Edition
I cant start my computer because system32\driver\isanpn.sys is missing or corrupt
You need to replace that missing or corrupt system file. If you don't have your disk, you can borrow someone else's Windows XP disk (SP2) because you will need an XP disk to access the recovery console to replace isanpn.sys file.
Here's a link to the full steps on Microsoft's website to go to the recovery console and replace that file:
http://support.microsoft.com/kb/315311
Apr 16, 2009 | Microsoft Windows XP Home Edition for PC
Application rtl100.bpl
Hello!!
Insert ur XP cd and boot it thro the cd and enter the repair console and try FIXBOOT command .. or try the other method .. run msconfig .. and disable the error in startup menu .. thanks for using fixya!!
Feb 23, 2009 | Dell Microsoft Windows XP Home Edition
Labtop wont boot...only has a blinking curser
1. Turn on the PC and press the F8 key repeatedly when the first screen appears.
The Windows advanced options menu appears.
2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
3. Select Microsoft Windows Recovery Console .
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
6. Press Enter , do one the following:
  • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
  • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered.
Dec 26, 2008 | Computers & Internet
Startup problems
this is telling you that a Scan/checkdisk program is running.
to get rid of this, run scandisk within windows, also go to Start/all programs/startup and remove from the startup if applicable.
to bypass on boot-up, simply press enter beefore the program Starts to run.
Mike @ compurepair.
Mar 08, 2008 | Computers & Internet
Compaq Presario Notebook Logo
115 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
