Cannot open door as handle broken for indesitw103
Door handle of machine has broken clothes stuck inside as cannot open door
  • 566 Answers
Hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
Posted on Oct 21, 2008
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
HELP! Very urgent! I have a Hotpoint Aquarius WD440 washer/dryer and the door handle has broken off. My clothes are stuck inside and I need them by tonight. How do I get the latch to open. I know I need to...
Slide a thin knife from 3 o clock door position against the frame to push the locking latch pin towards your left, only about a centimeter and the door would then release
Dec 21, 2012 | Washing Machines
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 14, 2008 | Hotpoint WF430 Front Load Washer
Samsung J845 Front Loading washing machine. The door is stuck, it seems the latch inside is broken?? Not sure, but am unable to get the uniforms that are in it out! It did finish its cycle. I just need to...
there is a part on the door that is broken. if your door handle is not automatically springing back to close when you open it there is a small thin piece in the door if you take it off that acts as the safety release for the child proof mechanism. If this is missing then you definitly have to find a new part as this helps to open the door. it is located next to the silver clip andit acts as the holder for the lock i too have the same problem and still are trying to look for part.
Mar 17, 2008 | Washing Machines
Door latch broken, clothes stuck inside!!
not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Apr 01, 2007 | Zanussi FLA1001W Front Load Washer
Washing Machines Logo
1,301 people viewed this question
Top Washing Machines Experts
