Question about Panasonic DVD-RV32 DVD Player
When I enter a dvd in the dvd player, reading will come across the screen, but I don't think the dvd is spinning and then stop will appear along with HO7. What does HO7 mean? and how can I fix it?
    President:
  • 3,130 Answers
Awwwww The old HO7 code!! This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry. If its an older unit you want to consider buying a new one as it may not pay to estimate the unit and have it fixed . The balls in your court now my friend. Good Luck
Posted on Jul 26, 2006
    New Friend:
  • 163 Answers
The 85% of the H07 I repair is the motor but more than the 50% of them I lubricated and thats it you will need a philiph screw driver and a thin oil such as wd40 I use trumpet oil but one friend of my use wd40 be carefull when accesing the motor disamble and asamble all parts gentely....good luck
Posted on Jul 27, 2006
I am unable to play DVD's and receive error message HD7. How can I fix this? I own Panasonic DVD-RV32 player.
I think you mean H07 - this means the traverse unit (which contains the spindle motor and the laser in one assembly) has failed. The spindle motor is the most likely problem; unfortunately this is not repairable at consumer level, it would need to go to an authorised service workshop where the whole unit would be replaced in the player, which would include a brand new laser. The other snag is the cost - a new traverse unit can cost around $200 + labour (including alignment and firmware upgrades)!
Save yourself the agony, and simply replace the whole player - cheaper than repairs. The RV32 was not Panasonic's best DVD player model.
Mar 01, 2011 | Panasonic DVD-RV32 DVD Player
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
When trying to play a dvd , it shows H07
Traverse unit (spindle motor & laser assembly combined) is most likely faulty. The motor part usually fails first, which stops the discs from spinning, so the inbuilt laser cannot read them, hence the error code. This can be expensive to replace.
Jan 28, 2011 | Panasonic DVD-RV32 DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
What formats will a Panasonic RV-32 read?
DVD only or mp3 or 4 but if you download a avi movie just get a converter avi to dvd.HOPE I WAS USEFULL PLZZZ RATE ME.
Dec 22, 2008 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Dvd player
check the motor and the strip that leads from the body of the lens to the circuit board.replace them
Apr 04, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
548 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
