Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire range CFEF357BC2
When i turn my range setting to Clean, then press 2 for 2 hours the CLN comes on and the door locks and a couple of minutes later the F9 message comes and and there's a beep and it goes back to the clock and the door unlocks...you can feel a little heat in the oven...but it doesn't continue...i shut the power off for one hour hoping it would re program but no luck...
  • 15,935 Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How can I get self clean to start?
To Self-Clean Using AUTO-CLEAN
1. Press AUTO CLEAN.
2. Press the HOUR and MIN "up" or "down" arrow pads to set the desired self-clean cycle time.
3. Press START. The oven door will automatically lock. "CLn," "LOCKED," "ON," "CLEAN," the Cooktop Lockout icon, and the time remaining will be displayed.
4. When the self-clean cycle is complete "END" will be displayed, and "PUSH"/"OFF" will blink alternately.
5. Press OFF/CANCEL. "LOCKED," "END," and the Cooktop Lockout icon will disappear from the display. "PUSH"/"OFF" will stop blinking, and clock will show the time of day.
6. Once the oven is completely cooled, remove ash with a damp cloth.
I hope this helps and thank you for a model number that made this possible for me to assist you. Good Luck
Apr 05, 2016 | Whirlpool GS563LXSS - stainless Steel Gas...
Tip
SELF CLEAN - FRIGIDAIRE OVEN
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
on Oct 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Do I need to do something other than push the clean button?
Hi Carol Moore, thanks for your inquiry!
From the information you have provided you need assistance using the self-clean feature on your Frigidaire range. Here are some basic steps to starting your self-clean:
1. Remove the racks within your oven.
2. Press Clean.
3. Use the "Up" or "Down" arrows to pick a three or two hour cycle.
4. You should then see a "CLn" on the panel. The door will lock and cleaning will begin.
I hope this information is helpful. -Matt
Dec 09, 2014 | Frigidaire FEF366 Electric Kitchen Range
How do i use the self cleaning button?
Hello LaRetta Madsen, thanks for your inquiry!
I see your question is labeled under model GLEFZ384GC. On that model range in order to use self-clean you would need to remove all the racks from the oven. Then you would press "Speed Clean" for a two hour clean or "Clean" for a three hour clean. You would then use the "Up" or "Down" arrows to select the time. After these steps the display should read "Lock" then "CLn" and it would now be in self-cleaning mode. I have included a link for your manual if further assistance is needed. Hope this information is helpful. -Matt
Frigidaire Manual Search Results
Nov 14, 2014 | Frigidaire Gallery GLEFZ384GC Kitchen...
How to use the self clean feature for a Frigidaire FES 355 ASF
Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
NOTE: When the oven is cool, wipe away any residue
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare Self Clean Oven
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
169 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
