Question about Olympus VN-960PC
I have a mac and I don't believe it's compatible.. am I right, or just screwing something up?
  • smtigg Oct 21, 2008
    thanks anyway
    Scholar:
  • 74 Answers
Seems the VN-960PC lives up to the "PC" part in that it is not compatible with the OS X operating system on the Mac. The last driver update was for Vista and I have not heard of anyone having success with using it on a Mac.
Sorry this isn't solving your problem. Guess the only option is to offload the files onto a PC and transfer your files on a flash drive.
Posted on Oct 21, 2008
Unable to move files from my mac to a external mac formatted usb storage drive
I believe the Belkin N750 is not compatible with Mac-formatted drives. I run Macs and while my N750 will see the drive, it is treated as read-only. Try reformatting in FAT-16, FAT-32 or NTFS.
Jun 27, 2012 | Belkin Computers & Internet
Tip
Winnie the Pooh Learning Toddler
This is for the Pooh Learning Toddler that came with the 2 disc bundle, running on a Windows XP operating system.
The software installed fine, but it was crashing when trying to open from the built-in "Launcher." I believe the error was Macromedia Projector related. Instead of opening with the Launcher.exe, open the WinnieT.exe program. You'll probably have to create a separate shortcut to your desktop/Start Menu, if you want a shortcut, that is. Before you open the program, some small adjustments need to be made. Right click on WinnieT.exe. Go to the Properties, then the Compatibility menu. Change the Compatibility mode to Windows 95 and check all the boxes below (I think the 640x480 resolution and the 256 colors is especially important to check). I believe it also ran for me in the Windows 98/ME mode, but there is no difference between the two. Good luck!
on Feb 19, 2008 | Disney 's Learning Toddler Pooh and Mickey...
Hello. i bought the axium 25 when i still had a powerbook. and that is all the drivers on the cd support. so i need a driver software for an intel mac or newer mac. i cant find anywhere. thanks!
Axiom keyboards are compatible with PC as well as Mac.
I don't know what DAW you are using but Axiom is compatible with several.
Take a look at Avid's hompage to solve your problem, lots of configurations and downloads.
I am sure you will find the answers right here :
http://www.m-audio.com/index.php?do=products.directlink
Regards
Sep 12, 2011 | M-Audio Axiom 25 2nd Gen 25-Key USB MIDI...
How do you believe in something that not exist
by opening your third eye and seeing all that is unseen and lacking form in our visible spectrum
Jun 07, 2011 | Google Chrome
I recently purchase a emac for my daughter, it's
Hi, unfortunately not every accessory that you can use for windows based pc's is good for Mac platform. This is why when you click on Autorun.exe the Mac won't install anything and won't work.
You should check if the device you want to use is Mac compatible. If you don't have the original package you should go to producers website and search for your device compatibility list.
If your device is not designed for Mac paltform you have to buy another device Mac compatible.
Let us know if you solved your problem
May 16, 2011 | Apple Computers & Internet
Can you run quark 4.1 under windows 7
Please! I am using Quark 4.1 on Windows 7 64 bit just as I did on 98, XP and Vista. Without a floppy, I had to copy the installed Quark directory to newer platforms then drag out a shortcut to the desktop. I just published some work to embellish in Acrobat 10. The installer doesn't work; Quark does! I expect it will work in Windows 8 if the MS programmers don't screw with procedures that work fine now.
Oct 04, 2010 | QuarkXPress 4.1 for mac
Error code 51330
Hello murz42
This error code is generated when the Wii console is unable to connect to the access point.
First of all, check that your router is compatible with the Wii www.nintendo.co.uk/NOE/en_GB/support/wii_support_5251_8071.html?id=8072
Are you using WEP or WPA security on your router? Log into your router using the default IP (if you don´t know this, or how to obtain it, consult your routers manual).
If you are using 64-bit encryption, the WEP key is a 10-character key consisting of numbers or the letters A - F. If you are using 128-bit encryption, it will consist of 26 characters. The WEP key must be hexadecimal. This means that it consists of the numbers 0-9, the letters A - F. It cannot consist of any special signs or letters. If you are using WPA, the Wii is compatible with the following types: - WPA - PSK (TKIP) - WPA - PSK (AES) - WPA2 - PSK (AES)
Next, check if your router is using MAC filtering. You still need to still be logged into your router. Find the section for MAC filtering, which is usually located under a "security" tab or something similar. If the MAC filtering is "on" or "enabled", enter the Wii´s MAC address to the list of approved MAC addresses. To find this, go to the Wii Channel menu, select "Wii settings" - "Internet" - "Console Settings". The MAC address is displayed on the first line.
Hope this helps. If you require any further help, please don´t hesitate to ask.
Good luck
ajblaj
Sep 06, 2010 | Nintendo Wii Console
Just got a MacBook Pro and it won't recognize my Insignia mp3 player. Is it possible to download to it from a Mac?
It is amazing to me when people say that the Mac "just works" and Windows is ****. And then they complete the sentence with the fact that the Mac is not compatible with or won't play some third party software or device as we see above. Believe me I know all to well the problems with Windows. But right now I can't get my mac to recognize my MP3 player either and I have had plenty of issues where my MBP locks up and I have to forcefully quit an app.
Jun 20, 2010 | Audio Players & Recorders
Lg ge20 and mac notebook
Is it compatible with OS 9 or OS X? If you have OS X and your disc is for OS 9 it won't work unless you have Classic installed and running. But it doesn't sound like you have Classic because I believe it would have tried to install in there by now on it's own. So when software says it is Mac compatible I always check further to see if it works with OS 9 or OS X.
Dec 28, 2008 | Apple iMac Notebook
Cant Install Or Replay Playlists NS-DA2G
I called insignia. An extremely rude cust. service rep. told me that the player doesn't work with itunes playlists and is ONLY mac compat. as a storage device.
What a crap answer! I actually can get songs on the thing and they play, but playlists are a lost cause.
Sometimes technology sucks.......
Nov 07, 2007 | Insignia NS-DV2G MP3 Player
Olympus VN-960PC Logo
351 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
