Question about Car Audio & Video
Braking brake pedal is very soft(vw polo 99,1,9d) rear wills not bloking propally
    Champion:
  • 242 Answers
Most likely you have air in your brake lines. You must bleed the air out of them. Hook small clear tube to brake bleeding nipple, the other end of the tube into a clear container filled with enough brake fluid to cover end of tube. Fill brake fluid reservior. Loosen lock nut and cinch hand tight. Start car, press brake pedal. While someone holds brake pedal depressed, open lock nut. If you are doing it right, you will see brake fluid in the tube. Tighten lock nut. Have person release pedal then press pedal again. Loosen nut and watch for bubbles. Continue pressing pedal and loosening/tightening nut until there are no more bubbles seen in the tube. Also check brake fluid reservior to make sure it is full. As more air is bled out of the brake system, your reservior level will go down. Do rear brakes first then move to front. If it continues to happen, you have a leak in your brake system.
Posted on Oct 28, 2008
Sticky brakes vw polo 1.6. 2002 model
The only thing that will hold the brake pedal down is the brake booster.
Jul 06, 2017 | Cars & Trucks
Soft brake pedal
bleed the brakes again . start with the rear right wheel then rear left then right front . do it several times and ensure there is no air in the system
Feb 26, 2014 | Geo Prizm Cars & Trucks
Brakes
Sounds like your master cylinder is sticking... Any abs or traction control lights on on the dash?
Nov 10, 2017 | Cars & Trucks
Front brake caliper sticking
Sounds like you have a seizing brake master cylinder.
Nov 10, 2017 | Volkswagen Polo Cars & Trucks
Vw polo 1.6 2002,front brakes get sticky
in the master cylinder is where to look
take it to an accredited professional brake shop and have it properly diagnosed
Nov 06, 2017 | Cars & Trucks
Hi can you help i have a vw golf gttdi on an 02 plate ive tried everything to get the brakes working but still when i turn the engine on they go soft
they will go soft a bit when engine runs as the servo is applying a lot more pressure its normal ,make sure you have removed the rear brake drums and adjusted the back brakes up manually and the pedal will go hard and the handbrake will tighten up as well
Nov 28, 2010 | 2002 Volkswagen Golf
I need to replace the rear brake pads on my Polo 1.9 TDi
this is a turn in caliper, meaning that as you try to compress the piston, you also need to rotate it clockwise. you can buy tool for this at nearly any parts store, and is fairly inexpensive.
Dec 28, 2009 | Volkswagen Jetta Cars & Trucks
Can you adjust polo rear brakes at the wheels or only on the handbrake cable (the car is a vw POLO and not a jetta?
hand brake is the only way to adjust them properly you can adjust them at the wheels but you will need to remove the drums then if adjusted too far drums may not go back on
Aug 19, 2009 | 1997 Volkswagen Jetta
Soft pedal,30 percent brakage
Air in Brake system need to be bled or master-cylinder is BAD. Noise in rear can be alot of different things NOT related to Soft pedal for example bent backing plate,wheel bearing etc. I would recommend removing brake drum and take a look at brakes in the rear contact if you need more help. Good Luck. Thanks for using FIX-YA
Jan 08, 2009 | 1987 Honda Accord
VW Polo Brake Sensor Light on but Brakes are fine!!
change the brake sensors on the front pads i had the same problem
Aug 12, 2008 | 1983 Volkswagen Rabbit Pickup
Car Audio & Video Logo
120 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
