Question about Sharp LL T15A4-H (Black) 15" LCD Monitor
SHARP monitor (-B, not -H) has 3 inch wide vertical 'zones' visible in LCD. Worse to the right.
There are 3-inch wide vertical 'zones' appearing on my screen, zones where the resolution appears poorer in each zone towards the right side of the screen and at it's best (ie. normal) in the left zone. There are distinct edges to these zones, but no dead pixels. They are most noticable when the screen is dark or blank (but switched on). The WIN XP 'starfield' screensaver is a good illustration. It shows clearly the defined zones getting more grey/white towards the right, while the left zone appears clear and normal. They sometimes flicker into view even on the brightest screens, and sometimes are only just visible on a fairly dark screen. The only thing the computer does which seems able to affect this phenomenon is if I try dragging a bright window (eg. My Computer) across a darker background, it appears to break the effect up into smaller chunks to the right of said window for a few seconds. I have tried adjusting every graphics card and monitor related setting on both the PC and monitor to no avail, I have tried it on many different computers and it stays problematic as described above. I have tried it with Linux, WIN 2000 and WIN XP (investigated most thoroughly with XP, with which I intend to use it) on several graphics setups. ALL THE SAME. HELP! I do not want to buy a new monitor (note the expense required) P.S. I may even try soldering if that is what it takes (I have basic skills in the area) (:-|)
  • Daniel Davies
    Daniel Davies Jul 27, 2006
    I have since phoned up Sharp Customer Services (again) and they have this time offered to replace the unit in a way which sounds very much like a product recall. Don't let this put anyone off adding solutions, as the replacement may not yet materialise and others need to know how to fix this and similar problems :-)
  • Daniel Davies
    Daniel Davies Aug 28, 2006
    The replacement did materialise. Anyone with this problem on this model of monitor take note!
SOURCE:
antiochpc
  • 1314 Answers
SOURCE: LCD monitor very dark.
The most likely cause for this problem is the backlight in the LCD. Over time, this light gets dim causing the problem you describe. I have never actually replaced a backlight myself. With the price of monitors these days, even if I could find one I don't think it would be worth my time and money to replace. But if you want to take the chance, try finding a monitor with a cracked LCD on ebay or look at the back of your LCD screen after you remove it from the monitor and see if someone is selling a used one somewhere by searching for the model number of the LCD screen.
Posted on Jun 10, 2007
Nitrotrike
  • 589 Answers
SOURCE: I have a kyocera kc 100 viewer and it wont wake up the pc monitor can ya help?
I'm confused as to how you're connecting this with s-video. Are you using an RGB / s-video adapter?
What is the exact monitor brand / model?
Posted on Jan 12, 2008
IrishDruid
  • 2712 Answers
SOURCE: Monitor menu screen appears on screen
Try a hard reset: Unplug from power source, disconnect from PC and wait for 10 minutes. Reconnect everything and see if the issue is resolved.
If not, then you either have a loose contact on the menu button or failing circuitry. I'd recommend calling Sharp tech support in this case..
Posted on Jun 14, 2008
SOURCE: Power button won't turn monitor off?
Alternative : Download Turn Off Monitor Utility from http://www.monitoroff.com
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Posted on Feb 14, 2009
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Vertical washed out lines in Dell 2208WFP monitor
The problem is in the LCD panel, the cost would be more than a new monitor by far.
Jul 09, 2012 | Computers & Internet
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Feb 06, 2018 | Sony BRAVIA KDL-32S2010 32 in. LCD...
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | ViewSonic VX1932wm Monitor
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Sharp LL T15A4-H (Black) 15" LCD Monitor Logo
42 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Siul Oyaratgam
Joe Negus
Joe Negus
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
