Question about Radio Communications
How to find hidden menu on yeasu 857d
How to find hidden menu on yeasu 857d that sets the automatic volume control /swr?
    Scholar:
  • 66 Answers
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Posted on Oct 26, 2008
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Best audio settings for ft-857d
Default settings should work fine. What mode are you operating in? Voltage ! Swr? What microphone? Too many variables. Not enough info.
Feb 08, 2016 | Yaesu FT-857D transceiver
Indicates SWR when I know the antenna and the dummy loads are 50 Ohms; so it reduces output.
Then there should be an internal unit problem in the swr detector line like a bad diode or a bad connection between it and the output coax connector.
Aug 27, 2013 | Yaesu FT-857D transceiver
857d does not display tunr icon when set up for atu operation
In the extended menu, double check the "tuner mode". Sometimes the 857 requires a "factory reset" (also in the extended menus) to get it working with external antenna tuners.
Aug 09, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
AUTOMATICALLY CHANNEL / VOLUME AND MODE CHANGING
please check touch key board i think it is defect
thanks lal electronics
Jul 15, 2013 | Insignia 32" 720p Flat-Panel LCD HDTV
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
M I VOLUME IT IS BLOKT END AI DONT NOU TOW GO INSAID TOW VOLUME MIXER HAW AI DOW DIS
Look for the Volume Mixer icon on the bottom right of your screen in the toolbar near the time. It may be hidden so click the "
If the Volume Mixer icon is not there, go to the Start Menu then click the icon for Control Panel. In the Control Panel window, select Sounds and Audio devices. Once in the settings for Sounds and Audio devices, there should be a checkbox for the option to "Place Volume Icon in the Taskbar." If no checkmark is there, click the box and then click on "OK". Now the Volume Mixer icon should appear in the taskbar.
Proceed by clicking this icon to launch the control panel for Volume Mixer. From here, you can change the volume settings for your computer and specific programs. Be sure to adjust the Master Volume setting.
Feb 28, 2011 | Dell Inspiron 6000 Notebook
Unlock volume control
you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
May 20, 2010 | Apple iPod nano
Ipod Nano can't unlock volume lock
on my ipod the volume limit is a software setting in the menu that does not require any kind of passcode so you have me a bit confused as to what you are asking
Oct 13, 2008 | Apple iPod nano 3rd Generation
Radio Communications Logo
678 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
