Question about HP LaserJet 3055 All-In-One Printer
Comm error 232 & no fax detected when receiving
On my fax activity log I have the error message 232 or no fax detected. This appears to be an intermittant problem. I need a fix please.
  • nont Nov 14, 2008
    same as above
  • Anonymous Apr 02, 2009
    Same as you
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Posted on Nov 18, 2008
I receive 1 page of an incoming fax but then the next page is a fax call report saying comm error 232
Try this...
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
Mar 31, 2010 | HP LaserJet 3050 All-In-One Printer
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
I have hp laserjet 3050 and i not able to receive fax
Hello Rupesh,
Following is the description for Error 232
A communication failure (comm error) has occurred between the two machines. OR The user at the remote machine may have pressed CANCEL. OR The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
  1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
  2. If the error persists, and error correction is in use for the fax session, disable ECM
Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
Follow the steps below to disable V.34 setting.
  1. Press Menu/Enter.
  2. Press the < or > buttons to select Fax Setup, then press Menu/Enter.
  3. Press the < or > buttons to select All Faxes, then press Menu/Enter.
  4. Press the < or > buttons to select V.34, then press Menu/Enter.
  5. Press the < or > buttons to select OFF, then press Menu/Enter to save the selection.
top
Disable or Enable the ECM
  4. Press the < or > buttons to select ECM, then press Menu/Enter.
  5. Press the < or > buttons to select OFF or ON, then press Menu/Enter to save the selection.
    NOTE: The default setting for ECM is ON.
Dec 20, 2008 | HP LaserJet 3050 All-In-One Printer
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Apr 17, 2008 | Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer Logo
1,910 people viewed this question
Seeker5211
Seeker5211
