Question about Viking VWH3048 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
Lights went out .changed lights . will not work . all fans work
  • reshmachhabr Nov 16, 2008
    Viking hood...all 3 halogen lights do not work, fan works
  • Anonymous Jan 08, 2009
    I have same problem but it's with a KitchenAid range hood... all lights out but fans still work.
    Problem Solver:
  • 6 Answers
The dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
    New Friend:
It's the reostadt. Fairly easy fix, see the other posts.
Posted on Jan 15, 2013
I can't get the halogen lights out of my hood i tried prying but no luck
Posted on Jan 24, 2010
Name of sensor too replace for radiator fan if changing thermostat doesn't work. Left side was changed, worked then both stopped working and the needle went to H.
Unless you have a check engine light on then the sensor (called the ECT sensor) in question is not the problem, do you have a C.E.L. on in the dash display? Have you tested the fan motor, it is ok? Is the cooling fan motor getting power when you jumper the fan relay socket?
Nov 01, 2016 | Cars & Trucks
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Replaced bulbs in my Viking DFS423B and still not coming on.
That was a DEAD Electrical short. If your talking about all the bulbs, it's probably at a fuse box. Start by checking all the fuses (under the hood too) Ck all the fuses anyway and that's the circuit where the trouble started if you find a bad fuse. More than one or two fuses your best bet is pro help unless you have wiring diagrams, test light & multimeter. Also look for burn marks on the wiring where you heard the POP.
Sep 24, 2015 | Cars & Trucks
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
Ceiling Fan Lights won't stay on
Try changing the frequency on the receiver & transmitter.
Nov 24, 2013 | Dryers
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Viking VWH3048 Kitchen Hood Logo
2,068 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
