Question about Yamaha AX-596 Amplifier
Internal breaker? or overload protection keeps tripping.
I am running a DJ's mixing board with a CD player and Ipod connected to it through the aux input on my AX-596. The speaker A wires go into a Niles SVL-4 speaker selector and out to 4 pair of 8 ohm 100 watt rated speakers. The amp has begun switching into the standby mode after playing for 45 minutes(roughly) and more frequently after that. Is the amp overheating? Is it posible to run the mixing board through this amp? I am carefully not to push the mixing board into the red.
  • spitkicker Oct 24, 2008
    Hi Robotek,
    The speakers are all rated 8 ohms and that is what I have the amp switched to so I believe 100 watts is the maximum output. This equipment is in my bar and has worked well for many years playing CD's through the 4 indoor speakers and 4 outdoor speakers. We only experienced this problem when we decided to try to send the DJ's equipment through our amp.
  • Jango Fixit
    Jango Fixit Apr 14, 2013
    https://www.facebook.com/jango.fixit?ref...
  • 38 Answers
Get the top off and identify the 2 main huge filter capacitors, 1 at the end of each heat sink.. At the base of each u will see a 47 K Ohm resistor covered in white glue extending from the cap to over the resistor's body.The resistors are numbered R141 and R142 for left and right channel respectively. Cut and strip away all the glue spilt on the resistors. For added measure replace the two 47 K Ohm resistors.
Crank up the volume and enjoy!!!
Jango
For pics illustrating the afflicted region check out my Facebook page ;
https://www.facebook.com/jango.fixit?ref=tn_tnmn
Posted on Apr 14, 2013
  • 1,512 Answers
Hi spitkicker
Can you tell me a but more about the circumstance you are using the Yamaha.
The speaker switch you are using also has a strict rating of 100wrms Driving it with the 145 wrms of the ax596 may damage the switcher. You also should have the protection circuitry of the Niles engaged to when using the configuration of the speakers you have.
If you are operating the amp at high levels into the speaker system(whether the mixer is red lining or not), balanced out by the SLV4 to 4 ohms, it may well be suffering from overheating, or has developed dry solder joints associated with running hot that is causing it to go into protection mode. Any amp has to work alot harder to drive a 4 ohm load, and with multiple speakers and impedance correction circuitry will be presenting a rather complex load to boot.
If you are using it in a commercial situation and running at higher output levels for extended periods, you may be better to upgrade it to a fan cooled PA style power amp that is engineered to operate under these conditions. Domestic HiFi is not built to cope with long standing high power operation and may well fail prematurely
If it is over heating, you may be able to overcome this by moving more air about the yamaha and reducing the power level you are running the system at. Happy to talk further with you about this. Let me know how you get on :) Cheers
regards
robotek
Posted on Oct 22, 2008
  • Graeme Ross
    Graeme Ross Oct 29, 2008
    Hi again,
    Thinking that it is perhaps possible that you are running higher levels with the DJ rig, than before. Would be the most likely difference between the old and new setup. I do not suspect the DJ gear is causing the problem. Just checked the specs again, and you were right, 100rms into 8 ohms, however, the load offered by the switching unit to the amp in the configuration your are running is 4 ohms. The amp will deliver 220 ohms dynamic power into 4 ohms. You can sight the specs from the Yamaha manual here, At any rate, the AX596 is a decent HiFi stereo amp and is capable of driving loads down to 2 ohm.
    The gut feel I have is... that the amp has dry solderjoint issues that could well be heat related, hence the shut down after a "warmup period". This causing the shutdown when these dry joints cause either a thermal runnaway condition, or a DC offset to occur in the output stages. Either way, resoldering about power components output stages should resolve the issue for you. The amp IS capable of over powering the impedance matcher, although depending on the configuration, if it is a switching only device, should not be too much of an issue. Some operations of it, particularly with constant load conditions setup for using tube amplifiers may. This is not the case in your setup.
    regards
    robotek
  • shadycobble Sep 25, 2011
    Robotek I have a Niles svl4 and sum how the two piece speaker connectors to this have suddenly dissappeared do you have a place where I hay be able to get new ones?
Rainbow pn-2e circuit breaker
The circuit breaker could be defective.
Aug 19, 2016 | Rainbow E series Canister Wet/Dry Vacuum
Brand new out the box dw716 dewalt compound dual bevel miter saw cut one board & quit. Left it alone for about 10 minutes & it worked when we came back. Made about 10 more cuts & it stopped again. We are...
I would return it to the store, or have it fixed under warranty. You obviously have a defective saw. Dewalt is a reputable company, and they make high quality tools, but defects do op up once in a while from all manufacturers.
It sounds like your saw has a defective heat sensor, and it is sensing the temperature incorrectly and shutting the saw off to protect it.
Dec 12, 2014 | Saws
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
GE electrical house breakers keep tripping. Any problems or recalls
You may have overload that power circuit with too many appliances.
Check the load of each of the appliances on that power circuit, add them together and check to see that it does not exceed the rating of the circuit breaker.
OR
You have an overload or short/fault on an appliance on the power circuit that is protected by that circuit breaker.
To identify the faulty appliance, disconnect all the appliances on that circuit and then connect each appliance one at a time to see when the circuit breaker trips out. When that happens you have identified the faulty appliance.
Jan 21, 2012 | GE Hammering
The OVERLOAD on my Marantz PM 44-SE is tripping out even at very low volume setting - using any of the inputs with either speakers connected or disconnected. I can even hear it tripping when no inputs or...
Overload is another form of protect mode. See the link below for an explanation of protect. Also, in your specific case, the problem is definately internal to the amp rather than an external cause. Expect a parts cost in the $40 range. Feel free to post additional questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 01, 2011 | Marantz Audio Players & Recorders
How do i get my ipod to play through my cd player
There are two ways you can use your ipod through your HU.
1. You can use the Aux port (located in the rear of your deck), which you will have to run AUX cable and connect it to the Ipod. Mind you this set up won't charge your ipod. Have to change the source to AUX for sound.
2. Through the USB cable that is included with the system connect your ipod (From the looks of things USB connection is also in the rear of the deck). Hit the Ipod button and that should be all she wrote.
Jan 10, 2011 | Pioneer FH-P800BT Car CD/ MP3 Player
HOW DO I HOOK UP AN IPOD TO A CD MIX2 , i hooked it into the aux on the back, i didnt get no sound evevrything was hooked up ,
You would need a Stereo jack to RCA cable. Input into Aux channel in rear, make sure your switch on faceplate is set to Aux. You may also need to turn up volume on the ipod.
Dec 07, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
When playing an ipod or laptop with my numark cd mix 1 is sounds distorted. What could be the problem. Both are plugged into the aux
I would start with the audio jack that you are using from the ipod/laptop to the numark it could be falty. Try also a couple of other audio players and see if you are getting the same results... the plug in on your numark my be faulty or dirty to where you are not getting a good connection to the machine. Hope this helps
Oct 17, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Is it possible to connect turntables and mixer to Acoustic Wave Music System 2 through the Aux, and simultaneously play a backing CD so that both can be heard? Eg, scratching vinyl over a hip hop beats CD.
Yes.
A traditional turntable requires a preamp inline with it to PRE amplify the minute signal produced by it's cartridge. Most setero receivers and preamps have Phono connection and internal preamplification strictly for that purpose. Many mixers out there have a Phono section or two, too, so your mixer will determine what you can do with vinyl.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
The mixer can send its output to the Aux input on the AWMS-2.
If you have only the internal CD player I don't think you will be able to do what you want. Reason: the AWMS-2 doesn't have a traditional Tape Monitor circuit which would allow its own internal program (including AM/FM) to exit to your mixer and come back in via the AUX. Selecting AUX disables its output. Thgis is to preevent a potential feedback loop. The AWMS wasn't designed for people who want or can control complexity in their listening.
If you have the external 5-CD changer or another CD source, you would be able to run all that through the mixer prior to its entry into the AWMS-2.
Sep 24, 2009 | Bose 901 VI Main / Stereo Speaker
Aux
there is an interconnector to connect this unit to the aux source (CD-RB20/CD-RB10)(sold seperately).
After connecting, press SOURCE until AUX appears in the display.
Press "play" on your ipod.
i sincerely hope this answers your question.
Jul 18, 2008 | Pioneer DEH-P80MP CD Player
Yamaha AX-596 Amplifier Logo
558 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
