Question about HP Officejet 5610 All-In-One InkJet Printer
No scan options for HP5610All in one printer
Help
    Novelist:
  • 180 Answers
Either using Windows Vista or Windows XP you can do this troubleshooting steps
> click on this link http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-45265-1&jumpid=reg_R1002_USEN
> if the software you download will not resolve the problem
> open "hp solution center"
> click settings > click scan settings > click scan to set up > if a screen pops up click on restore defaults then click apply or ok and then close the solution center
> try scanning again
> if this would not resolve the issue then you need to uninstall the software of your printer using the add/remove programs. you need to remove all softwares related to the printer.
> then download the software of the printer in the hp website
> reinstall the software that should solve the problem
Posted on Oct 22, 2008
  • 70 Answers
Are you using vista?
If so check under windows photo gallery you will find scanner there
Posted on Oct 21, 2008
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Had been scanning pictures into computer and now i
First let us remove the No Scan Option.
First try to Scan from HP director or HP Solution Center.
If it is scanning, perform the steps given below to resolve the issue.
Open HP solution center/HP Director:
Click on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
Jun 02, 2010 | HP Photosmart 3210 All-In-One InkJet...
Having a problem with the scan function on my HPC7280
Not too sure on this model, but if there was no options, perhaps the machine has not been set up correctly to scan to a folder or application.
This FAQ/Guide from HP shows you what you need to do to correct set up your printer to make scans.
Dec 11, 2009 | HP Photosmart C7280 Printer
Printer works, cannot scan (same issue as gemrise)
Yes, just like it says, you need a scanning software running on your computer, there are no options until you have the scanning software running and it knows where to send the image and how to save it.
Nov 20, 2009 | HP PSC 2410 All-In-One InkJet Printer
No scan option when scan button is pressed
Try to reinstall the driver. If not help try scan with other program like "Microsoft scanner and camera wizard".
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
I have mx310 copier/printer/fax/scanenr. i can copy and print but it will not scan. any suggestions?
I have a Canon Pixma MP470 and my scan control option is in the solution menu with the import option.
Try this: click start, click all programs, choose Canon utilities, choose solution menu, slide right and click on solution menu, your screen should show scan/import option, click on scan/import and chhose scan. I hope this is helpful, Good Luck.
Aug 26, 2009 | Canon PIXMA MX310 All-In-One Printer
HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Mar 04, 2009 | HP Photosmart 3210 Printer
WorkCentre C2424 Scanning Mac OS X.
Well I haven't necessarily scanned often, but i do know if you open up a program such as word, Excel, PowerPoint, Photoshop, Corel, etc... You are given an option to scan. That way you can scan information, images and such to that program in which you use. C2424 wont give you any support because its a primary printer but the drivers should include drivers for the scanner and the computer to interconnect. If you have any photo like software on your mac. Try looking at the options at your top menu for an option or "import"
Many times it will give you the option to scan from a device.
To scan to computer its software based. Also on the Panel on the printer you should be given an option to scan. If printer is connected by USB it will be easier to detect scans from panel, but if your printer is connected via Ethernet it will be different.
I hope this helps. Try using a program that you can use to edit pictures or display. You should be given an option.
I hope this helps. Let me know what you do? and possibly i can mirror what you do on my own mac
Oct 16, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Aug 31, 2008 | HP Photosmart C6280 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
328 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
