Question about Proview PX-986 19" CRT Monitor
How do I fix a monitor
My parents' monitor for their computer has been acting up. The three lights on the bottom of the monitor that control the stretch, color etc flash rapidly and when you try to adjust the visual settings it takes several seconds for it to work or does something completly different. Is there a way to fix that or do they just need a new monitor? It's a Proview 19" Thank you!
  • Proview Master
  • 2,000 Answers
The age and much more power consumption and different dangerous places with high power ask for knowledge of focussing ,anode ,flyback (horizontal) and primairy rectification power on differend places , is not without danger , how to unload the display tube, and much more and in most case the line transformer flyback transistor and capacitor could be damaged. is not useful , a new monitor has more advantage and most of them are not to expensive to buy.
Posted on Sep 03, 2017
5 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: Monitor works on one computer, but not the other
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Posted on Jun 26, 2007
SOURCE: proview pl926wbi 19 inch monitor case removal
Hey Bob,
I just did this and the following worked for me.
1. Orient the monitor so the base is facing towards you and the top is facing away from your. Make sure the monitor is LCD up.
2. Grip the gray plastics just above the buttons and flex it up and towards you. You should be able to see the button control panel.
It should flex enough for you to rest the bezel and screw holes on top of the underside bezel. When doing this you have to wedge your finger tips between the LCD panel and the gray plastics to separate it. The trick is not to apply too much pressure to the LCD panel itself so you don't damage it. Almost all your pressure should be applied to the gray plastics as you lift "upwards" away from the LCD.
3. Once you have done this, you need to slide the bezel away from you towards the top of the monitor in order to release the side tabs and the top tabs. I found the best way to do this is to push upwards or away from you along the bottom left and right corners of the monitor and move upwards along the side of the monitor.
4. Once you have release the side latches the whole bezel should just slide upwards or away from you.
Note: When replacing the bezel you need to start from the top and insert the top tabs first. Then align the side tabs and last align the bottom button portion of the bezel.
Posted on Dec 10, 2007
  • 20 Answers
SOURCE: Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Posted on Dec 29, 2007
Geekman
  • 32281 Answers
SOURCE: Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Posted on Jan 29, 2010
I know of Spyrix.com keylogger as my friend is using to monitor her children so a keylogger is not illegal it is ligeal as it has several benefits.
If you want to monitor children for parental control,you'd better tell your children about the monitoring and achieve an agreement that you won't invade their privacy.And if you want to realize parental control on PC, you can use such kind of program to block sites and time control,etc.I have used parental control program of anykeylogger(www.anykeylogger.com),it works well,you can also find other fine programs on the Internet.
Nov 24, 2013 | Computers & Internet
When displaying pad lock
control panel -> parental controls -> click on selected user name that have parental control ON and switch it of -> reboot HOPE IT WORKS !
Jan 22, 2013 | Dell E173FPb 17" TFT LCD Monitor
I never had password for parental control do not want one
Now that the kids have left for college, the need for parental controls on the family computer is no longer necessary. If you're stumped as to how to remove the web-blocking software, don't worry. It's an easy process no matter if you use a Windows- or Mac-based operating system.
To Remove Parental Control Software from Windows XP b> Click "Start" and then open up the "Control Panel". Click on "Add or Remove Programs". Wait for the program list to populate. Scroll through the list and identify the monitoring web software such as NetNanny, WebWatcher or similar. Click on the web monitoring software. To the right of the highlighted software is a button that says "Change/Remove", or two buttons, one "Change" the other "Remove". Click the appropriate button that will remove the web blocking software. If you get a pop up asking if you wish to continue, click "Yes". The Windows Add/Remove utility will proceed automatically from this point on. b> To Remove Parental Control Software from Vista or Windows 7 b> Click "Start", then open up the "Control Panel". A new window will open up, select "Programs and Features". The heading will now read "Uninstall or Change a Program". Scroll through the list until you find the web blocking software you wish to remove. Select program. The action "Uninstall" will appear next to the word "Organize" in the bar above the program list. Select "Uninstall". Click Yes when the message box pops up asking if you're sure you want to uninstall the parental controls program. The uninstall utility will take over from there. b> To Remove Parental Controls on a Mac b> Open the "System Preferences" folder. Select "Accounts" under the "Systems" header at the bottom of your screen. Select the user account name from which you wish to remove parental controls from the left hand column. Uncheck "Enable Parental Controls".
b>
Jan 16, 2013 | Acer Aspire 4315 Notebook
Hello, My Graco monitor shows a red light instead of the normal green light and it says "discard jetez". It also beeps. What could be wrong?
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Mar 12, 2011 | Graco Imonitor Vibe 2791vib Digital Baby...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
When I made my Xbox Live acc I accidentaly made it to young
Parental setting can be changed by going into the Dashboard, -> System settings-> Parental controls-> Upgrade account-> YOU WILL NEED A NEW CREDITCARD TO DO THIS Red Ring 2 so its like the top Left and Botom left lights up? Means its over heating, If it does it on startup, It may be progression to ROD, thats three lights, or a light may be out and it is the ROD Call 1-800-4MY-xbox
Jun 04, 2009 | Microsoft Xbox Console
How can i block certain website (mostely the torrent site)parentally. And prevent from downloading the torrent PERMANENTLY.
I use TrendMicro (about $40/year for three machines). You have decent parental control with it. You may also use "Resticted Sites" settings in Internet Explorer but it may not be as secure for you. The TrendMicro software requires a password to allow settings to be changed...not sure about IE.
Apr 30, 2009 | Computers & Internet
Hp monitor 18" LCD color d5063
Turn the monitor upside down and turn on the lights in the room.
Then you will see a location for a power cord, remember three wires/prongs. Good luck.
Jun 21, 2008 | HP Pavilion F1703 17" LCD Monitor
Proview PX-986 19" CRT Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Bastian Farkash
Bastian Farkash
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
