My Brother MFC-7840W works great but there is a loud squeaking noise now when printing--how do I fix?
SOURCE: Brother MFC 8440 makes very loud noise when printing/copying
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
SOURCE: Brother HL5250DN makes loud squeaking
This is not a problem but it can be early signs of the drum and rollers wearing out. When it does die, I suggest buying another printer.
