Question about Liquid Video MVBG619 Portable DVD Player
Has anyone successfully connected an external device to the video inputs?
While I don't own the "MVBG619" *specifically* (the "LIDM-830" to be exact), it shouldn't matter across units.
I just purchased a used 8" LV portable DVD player with the intent of connecting external devices (VCR, etc) to it.
There are three 3.5mm "Composite", "Audio" and "S-Video" jacks on the unit and an "In/Out" selector switch to set the direction of the plugs.
The unit came with a "Y/R/W RCA Component to 3.5mm" cable. I plugged it in, switched the direction to "In(put)", but all I get is a dark, unviewable image (like I'm on the wrong channel) and no sound. (Yes, I did try switching the VCR's switch from Channel 3 to Channel 4. No diff).
I've used the Component video from the VCR to a TV with Component jacks and it works fine.
Has anyone else been able to display video from an external device on the player? I'd also like to connect other things to it. Thx.
    Master:
  • 586 Answers
First, the R/Y/W connections are "composite" not "component" video. Component connections are green/blue/red and are a superior connection basically on the same level of quality as HDMI. If you have your TV and VCR connected this way, it will not be compatible with the RCA Y/R/W. I think you are confused as to what component and composite connections are. And, why would you want to connect a DVD player to anything at all other than your TV or a DVD burner? I don't get it.
If you are using R/W/Y, that is basic and the least sophisticated connection available. Further, if you connected this unit to your TV, then you would want to set its connections on "out", not "in", then plug them into your TV.
Posted on Mar 10, 2017
Testimonial: "Thanks for the response, but I don't know why the date on this question was changed to today (3/10/17). It was originally posted nearly 11 years ago in 2006 (note date on replies.) :D I originally asked about this b/c I was trying to connect a digital TV receiver to it. :)"
  • Joe Ball
    Joe Ball Mar 10, 2017
    You are quite welcome. Strange it would still be floating around 11 yrs. later. Best wishes!
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Half the screen is dark
Sounds like half your backlight is not functioning. The only thing I suggest is to call the manufacturer thats listed in your user manual and see what they think it will cost to repair unless its still in warrantee. There are no user serviceable parts inside of this unit so i dont think it would be a good Idea for you to attemt to take it apart as it may be a system to dissasembly and you make tear or break on of the small flex cables. Good luck
Posted on Jul 04, 2006
SOURCE: Liquid Video MVBG619 Car power Cord
Hi Lauri3 just wondering if you would have just 1 of the remote control units for this dvd player for sale. Please let me know.
Thanks
veryounique@hotmail.com
Posted on Aug 18, 2008
Why would the tv say no signal
If you have selected an external input and there is no device connected and turned on, the TV will give this indication. Select another input (TV, HDMI, Video), or connect and turn on an external device. When there is a signal to the selected input, the "no signal" indication will go away, assuming the input is working correctly. I hope this helps.
May 09, 2014 | Televison & Video
Tip
LG ENV as a touch connecting to an additional input
<p>You can use the 3.5 mm headphone jack on the Touch LG ENV to an audio device via an auxiliary input. If the audio cable is connected, the phone automatically updates all sounds cable. Then you can play music from the music player devices, such as car radios and systems external speaker. The 3.5 mm audio jack is a stereo connection, and is the audio standard for many electronic devices. <br /> <p><br /> <p>1. Connect one end of the audio cable to the 3.5 mm headphone jack on the Touch LG ENV. <br /> <p><br /> <p>2. Connect the other end of the cable into the auxiliary input device you are connecting. <br /> <p><br /> <p>3. Change the input of your audio device to take extra. Car radio, press the AUX button. See the device manual for specific instructions. <br />
on Aug 05, 2011 | Cell Phones
I try recording from a home video to a dvd and it does't recordc_
You don't specify what you are playing the 'home video' on or how you have made connections between equipment.
There are input terminals under the front, left hand side, flap for recording from external video equipment. There are S-video input and Audio/Video inputs (yellow, white and red). Before selecting record you have to Press (Input Select) to select the input channel for the equipment you have connected.
I hope this may help you achieve what you require.
Jul 14, 2011 | Panasonic DMR-E55 DVD Recorder
I've had a number of vcrs and vcr/dvd players over the years. But for some reason, I cannot set up this machine. I set up all of the cables exactly like I always have and the way that is instructed, but I...
These days the video input channel depends on the TV and any other equipment in the sequence. I've seen component video come in as Line, Channel 3/4 (with a switch on the video device), Aux1, Ex1, AV1, Channel 60 (I think that may be specific to satellite dish receivers). If the remote has an input button, try that (alternatively, look in the menu for source options). One thing to try: press the PSCAN button on the DVD remote (to toggle off the Progressive scan).
On some TVs the channel for the video is reached by going down from Channel 2 (this works when no channels are programmed into memory and the intervening channels are skipped).
What TV are you connecting to the DVD/VCR player? (If it is an older TV and any external device was connected to either channel 3 or 4, check that the TV works with any input device. I had a 19 year old TV (coax in only) that was damaged and no external device worked.)
I wish that I could be of more help.
Apr 26, 2010 | RCA DRC8335
I need a car adapter for an 8" portable Liquid Video DVD player Model #LIDM-830
Radioshack makes car adapters for just about anything; they're called IGO adapters. Take your item in and they will match the tip and give you the adapter. It will run about $30 but it's well worth it.
Please give me a good rating if this helped! Thanks!
Dec 01, 2009 | Computers & Internet
The HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Jan 10, 2009 | Yamaha HTR-6140 Receiver
Thanks
Aug 06, 2008 | Liquid Video MVBG619 Portable DVD Player
Cannot see picture on screen
Take a LED flashlight, and shine it into the screen. Can you make out any picture hiding in there at all? If so The backlight, and or the inverter must be changed. Usually they will change both units together when you send the unit in for service. won't be cheap though. Could also be that the video connection to the screen was lost, or that the setting is for an external monitor. please comment back with more detail, and also if and how you managed solving the problem Good luck
May 08, 2006 | Liquid Video MVBG619 Portable DVD Player
Open Questions:
Liquid Video MVBG619 Portable DVD Player Logo
51 people viewed this question
Top Liquid Video Televison & Video Experts
Are you a Liquid Video Televison and Video Expert? Answer questions, earn points and help others
