REDDY HEATER PRO 200 WILL NOT STAY ON WITH TOP COVER ON
HELLO MY HEATER WILL NOT STAY BURNING WITH THE TOP OF THE HEATER ON , IF I REMOVE THE TOP IT WILL STAY BURNING AND WORKING FINE,ANY IDEAS THAT MAY HELP ME? I HAVE CLEANED THE FILTER AND IT DOES THE SAME THING WITH THE FILTER IN OR OUT .
  • Anonymous Jan 10, 2009
    my heater will not stay running unless cover is off (pro 200
  • 232 Answers
The nozzle is either restricted or worn to a point that the cone shaped fuel pattern is no longer producing a FOG, but is now producing a SPRAY and is not producing combustion. By removing the top cover the aerodynamics changes and allows the cone to expand & atomize better.
All bets are off, though, if you haven't checked the pressure on the air pump. Setting the pump pressure is easy but critical, especially if your heater has a glowbar & control board. Instructions are at www.reddyparts.com .
Check your heater over thoroughly for the exact model of your heater. "Pro 200" only designates a style and not all parts interchange from one PRO 200 to the other.
Posted on Oct 21, 2008
HEATER WILL NOT STAY IGNITED WHEN START SWITCH IS RELEASED
ayama794,
I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should help solve your problem. It is written for a reddy heater but reddy heat, all pro and dyna glo are all the same units.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 26, 2010 | All-Pro SPC-85 Utility Heater
Flashbacks on both burners. heater lights fine but after only a minute or so both burners flasnback and start burning behind the screens. this results in burner head and fuel delivery tube heating up to...
You may want to check consumer Products Safty Commision Regarding DESA Products Recall, of which All-Pro, Reddy Heater and MasterHeaters , are all Imported by.DESA Products.
Jan 06, 2010 | All-Pro All Pro Heater SPC-30R 14-30,000...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Replacing rotor on Readdy Heater
Remove top shell. Remove cover. Remove filters. Remove filter base. Then it should pull out. Check clearance on new rotor .003/.004 checked with feeler gage. Reinstall in reverse order. Reset air pressure. Good luck.
Jan 15, 2008 | Reddy R70ET Utility Heater
Reddy heater pro 110
Need parts for readdy Heater Pro 110 New
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
1,061 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
