Question about Gateway E-4200 Notebook
Floppy is always full even the ones out of a new box
Does the top box on new gt hold 2 helmets
Not an exact answer to your question as I don't know the topbox size, but even boxes that advertise as holding 2 helmets don't always do what they say. Depends on helmet style and size. They can say 2 helmets, but mean only 2 small size open face, not much good if you have 2 extra large full face ones (as in my case). Might be worth bearing in mind. Best way is to actually check one out yourself if possible. Hope that helps.
Aug 10, 2015 | Honda CBF 1000 Motorcycles
I have a JD D110 riding mower and the gas gauge always shows full. It worked for awhile and then I filled the tank and it now always says full. How do I fix this?
If the wire from the sender to the gage is shorted out to ground the gage will always show full. Other possible is a defective sender or gage,even on a new machine
May 28, 2015 | John Deere Garden
Cannot use the floppy disk of my CVP 65 as it appears the memory is full. It plays new discs, but won't record.
This sounds like it MIGHT be a floppy drive problem rather than a full memory... REMEMBER to ONLY try recording a file no bigger than what the floppy will hold which is 720Kb.
NOTE: The disks used in this are not the COMMON 3.5 inch floppies, but the older 2DD 720K floppies. They have only one hole on corners where the new 1.44 Mb ones have two holes.
To USE the 1.44 Mb flopies do this: Use an opaque tape to cover the hole that does NOT have the write protect slider. THEN most omportantly DEGAUSS the disk with a degausser. THEN Reformat the disk in the CVP 65.
The pre-formatted 1.44 disk when formated at the 720Kb used by the CVP 65 will have ARTIFACTS between tracks since the higher density also have half the track spacing and the formatting doesn't always clean enough width leaving artifacts between the tracks when formatted as 720Kb These ARTIFACTS can cause trouble.
The 720Kb disks are ESSENTIALLY unavailable anymore.
Jan 15, 2010 | Music
Bought a new USB external floppy drive. Copied a
You may have a virus causing this...OR your computer USB MIGHT not be putting out the required 1/2 amp current. That you can fix by using a powered USB hub.
Dec 09, 2009 | Memorex Computers & Internet
I have installed a new floppy hard drive but my pc does not recognise it. how do i activate it? and why is the green light always on even without a floppy inside it?
Get into your bios and enable the "A" drive in the bios if you haven't already. It has to show up in the bios for it to show up in the device manager in windows. Start at the bios and work up to the device manager and reinstall floppy drivers if needed.
Oct 14, 2009 | Computers & Internet
Always says not ready,green light is always on,will not read disk
I bet its faulty, try buying a new one, they arent expensive.
Aug 03, 2009 | Computers & Internet
Old floppy disk photo file is viewed in wordpad; just squares
Right click on the file and click "open with" on the new window select the program you wish to open it with such as "microsoft image viewer" then check the box that says "always use the selected program to open this type of file" then click ok and it should open in the program you selected
Jul 02, 2009 | HP Computers & Internet
BIOS UPDATE FAIL
Try making a disk again - use a brand new disk and check it for errors.
Feb 15, 2009 | Abit NF-M2S Motherboard
Stopped working all of a sudden
Hmnmm.... try getting a new IDE ribbon cord, your existing one may be broken.
Sep 28, 2007 | Sony (MPF920-Z/131) Internal Floppy Drive
Computers & Internet Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
